Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 04-27-2008, 09:08 PM
  #561
7 Second Club
Phil99vette's Avatar
Carpet is 100% done
Water lines are 100% done
Water pump feeds 3800gph of water @ 12 volts and we're running it on 16 volts. Supplying the pump with 1.5" lines.
Old 04-27-2008, 09:09 PM
  #562
7 Second Club
Originally Posted by NA$TY-TA
What The Min. Wieght at Budds for a Turbo Radial Car??? 3400lbs??
If so is Budds going to let them go faster then there cage cert for the class??
3400 is BB and turbo min, who knows what they are going to do. I don't thin they expected stine to run in the 40s the first night. He has been 60s multiple times.
Old 04-27-2008, 09:53 PM
  #563
ShiznityZ28's Avatar
Looks great Phil !!
Its getting close, hope to see it out soon!
Old 04-28-2008, 01:14 PM
  #564
7 Second Club
This morning was uneventful, basically cleaned up around the shop and started working on mounting the oil filter. I'm going to put it in the driver fender behind the tire, should be an easy place for oil changes. Ordered another round of goodies
-Aeromotive fuel pressure guage + adapter - will finish off fuel system
-12 hose for dry sump tank
-10 hose for turbo return to pan
-6 hose for transmission cooler - needed 10 more feet since we relocated it from the front to the water tank in the rear
- 18" of D stock to finish up the steering
- couple misc AN fittings
This week we should be able to:
Button up dry sump completely
Finish oil filter mount + lines
Finish up the Co2 lines for the WG, Boost controller and BOVs
Finish up the brake lines, need to run a single line from front to back for the rear brakes
Start the electrical portion of the build.
  #565
7 Second Club
Originally Posted by ShiznityZ28
Looks great Phil !!
Thanks man, when are you guys starting the turbo build?
Old 04-28-2008, 01:23 PM
  #566
ATVracr's Avatar
SOON !!
I hope it turns out as nice as yours !!
Old 04-28-2008, 02:36 PM
  #567
BADSZ28's Avatar
Looking great. 3800GPH?! Wow! What kind of pressure drop will you have accross that cooler on the water side? What pressure drop can the pump handle? How are you cooling the water after it passes through the cooler?
Old 04-28-2008, 02:38 PM
  #568
7 Second Club
Yes its 3800 gallons per hour. Don't know about pressure drop since its it wasn't rated, the water is going to a tank of rock salt and 3-4lbs of ice.
Old 04-28-2008, 08:07 PM
  #569
NA$TY-TA's Avatar
Phil,
Where do ya get the green hose and how much a foot??
Old 04-28-2008, 09:17 PM
  #570
7 Second Club
Andy Jensen turned me onto it a year ago....
Goodyear Spiralflex 1600 from MSC
Can't collapse it no matter how hard you try and its pretty lightweight.
Old 05-01-2008, 08:34 PM
  #571
7 Second Club
Made alot of progress today;
Finished:
Turbo feed line
Turbo drain line
All dry sump lines
Dry sump tank lines
Oil filter lines
Mounted Oil filter
Painted rear cage section
Installed fuel filter
Installed brake pads
Transmission lines
And soo much more...only a few days left.
Old 05-01-2008, 09:12 PM
  #572
RAGENZ28's Avatar
Almost done, hope you aint scared to drive it lol.
Old 05-01-2008, 10:43 PM
  #573
CamaroRacing12's Avatar
this is one badass custom build! and in a garage on jackstands!!
Old 05-01-2008, 11:10 PM
  #574
datsbad's Avatar
BADASS car with big dollar parts. I hope to see it someday .
Please , please tell me I dont see ZIP ties on this car underneath????
You have taken the time to do so much on this car , its the details that make a average car a awesome car . Either way its cool, but .......No disrespect intended either!
Old 05-02-2008, 03:07 AM
  #575
SSilverSSurfer's Avatar
did you do this entirely by yourself?
Old 05-02-2008, 08:46 AM
  #576
7 Second Club
Yes, you see plenty of zip ties. You'll also see some fiberglass tape. I needed to tie the hoes up and determine placement of the clamps. Zip ties will come off soon.
Old 05-02-2008, 08:48 AM
  #577
7 Second Club
Yes, I did everything in my garage. My wife helped out on disassembly and dad helped out on paint.
Phil
Old 05-02-2008, 01:23 PM
  #578
Old 05-02-2008, 06:46 PM
  #579
NA$TY-TA's Avatar
Hey Phil.... sending u a PM
Old 05-02-2008, 09:33 PM
  #580
7 Second Club
New turbo on left, turbo on right is a 78mm.
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
