Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 05-30-2008, 08:05 AM
  #681
7 Second Club
Phil99vette's Avatar
Originally Posted by Fireball
did you drive it around w/o the front bumper just to show off your craftsmanship?
No, I was soo excited about driving it I said F-it. Hopefully I'll have some dyno numbers tonight on low boost.
Old 05-30-2008, 10:04 AM
  #682
NA$TY-TA's Avatar
Everyone is on LOW Boost LOL
Old 05-30-2008, 10:24 AM
  #683
7 Second Club
Kyle - Trust me it ain't going to be on low boost for long. As soon as I can get the last fitting for my AMS its going to be full tilt.
Old 05-30-2008, 10:38 AM
  #684
RAGENZ28's Avatar
Good luck at the dyno Phil, looks like it is ready to go 200 mph.
Old 05-30-2008, 07:50 PM
  #685
stang50bangerz's Avatar
well i have been watching this project for the whole time and never once made a post.. but i have read all of the post.. and over all i rate it a 11 out of 10 on the thread.
its bad *** man keep up the good work and dont let the vette go to waste now that you have this monster..
BTW i love the painted nails holding up the baby. i hope they are not yours lol..
ill fill it up if i can go for a ride if im ever anywhere close.. cause the fastest i have been was in the in the wild street challege champ of 06's car. and its only been 8'teens..
Old 05-30-2008, 09:18 PM
  #686
7 Second Club
Well didn't get much done on the dyno. We made 8-9 pulls none on boost. A/F was so far out of wack it wasn't funny. By the 9th pull the car was running 13:0+-2 all motor. We pulled the charge pipe to tune it for the motor alone. Couple things we found out....
1) 4.5 degrees of timing all motor = almost 50hp
2) The water tank heats up quick needs to be changed every 2 pulls
Something in the tranny let go on the 9th pull. Talked to one of my tranny guys and he said that there is a small piece that could have broken which is common. Somethng to do with the shifter and getting the tranny into the correct gear. He said its a $2 part. I'm going to pull the tranny tomorrow get it over to Wayne and get it torn down, he said he can have it back same day.
Old 05-31-2008, 12:01 AM
  #687
RAGENZ28's Avatar
Sorry about the gremlins Phil, you'll get is sorted out
Old 05-31-2008, 12:22 AM
  #688
car_fixer's Avatar
did you weigh it yet?
hate hearing about those little things, but been there lol,
hope to see big numbers soon
Old 05-31-2008, 07:04 AM
  #689
Fireball's Avatar
how is your water heating up if you took the charge pipe off? I've always heard that pushing it without a charge pipe is extremely bad for the turbo as it can freewheel and overrev....
Old 05-31-2008, 08:07 AM
  #690
7 Second Club
We put the transmission cooler in the water tank. The car is almost done on the motor, the VE numbers are very close. I'm going to try adding timing to see how much we can get out of it. Switching from 24 to 28, the car made 45 more RWHP.
Old 05-31-2008, 08:08 AM
  #691
7 Second Club
I was initally plannign on stopping by and putting it on the scale but since the trans let go we packed it up and headed home.
Old 06-01-2008, 09:03 AM
  #692
7 Second Club
ulled the tranny today and decided its time to get a lift. Tranny fluid was clean, pan was clean still not sure what broke.
Old 06-01-2008, 04:25 PM
  #693
smokeum99ta's Avatar
You can do that with that " Big Money Grip" you have Looks like you'll have to do something with your garage door first. What kind of numbers did you get anyways? Or is it
Old 06-01-2008, 05:51 PM
  #694
borninatransam's Avatar
ive wondered how youve done it all along. youve got more patience for getting on the ground than i do. cant wait to see the numbers.
Old 06-01-2008, 06:49 PM
  #695
7 Second Club
We had too many issues to get any real good numbers but looking at the number trend from run 1 to run 8 we're moving in the right direction. The motor numbers were less than spectacular BUT considering we picked up ~50rwhp by adding 4 degrees of timing and everyone says we're going to end up with timing in the high 30s...we're going to be just fine. I can say we're trying to make 500-520rwhp on the motor through a glide with an unlocked converter.
The dyno did tell us....
- We were down 30+rwhp on the final pull due to IAT temps in the mid 130s vs 40s
- 24 to 28 degrees was worth big HP and we firmly believe its going to need 35-38 when its all said and done with.
Standing back and looking at the data, I'm happy where we're at.
Old 06-01-2008, 08:01 PM
  #696
JUICED96Z's Avatar
In the water tank for the turbo IC?
When I get around to finding me a nice notch fox (Turbo BBC going in it) I am going to run a seperate water tank for the tranny and another for the turbo. This may be what you have.
Glad to see your car is making some pulls, cheap parts to fix things are nice.... I need to get a fence up in the back yard for the dogs before I have some play money...
Old 06-01-2008, 11:58 PM
  #697
black98ws6ta's Avatar
I have heard the same...Phil are you not worried about it because you dont plan on spending much more time tuning n/a or you believe it is ok? Thanks.
Old 06-02-2008, 11:32 AM
  #698
7 Second Club
We got the big turbo installed this morning, had to grind the frame rail and the support to get it to fit since it was tucked up alittle more. Started on the downpipe and got a couple tubes cut and almost ready to be tacked into place.
My dad dropped off the tranny today, hopefully I'll have it back wednesday to install thursday.
Tomorrow I hope to have the downpipe finished so when the tranny gets back we can hit the track.
Old 06-02-2008, 11:33 AM
  #699
7 Second Club
Its going to be all good.
Old 06-02-2008, 01:44 PM
  #700
7 Second Club
ty_ty13's Avatar
some times what the dyno likes for timing and what the track likes for timming is a little different... i'd pull a couple degrees on the track just to be safe that when its loaded hard it doesnt detonate... there... thats my $.02.... lol
good luck and the car looks stellar!
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
