Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 09-03-2007, 05:54 PM
  #81
csjta2's Avatar
Nice work!!
Old 09-04-2007, 01:41 AM
  #82
pdd
pdd's Avatar
LOOKS AWESUM PHIL
Old 09-04-2007, 09:21 AM
  #83
7 Second Club
Phil99vette's Avatar
Thanks guys, did some work with the plasma cutter this morning, removed 32lbs of material from:
Dash bars
Dash box
Rear deck
Old 09-04-2007, 06:16 PM
  #84
07BlueDevilZ06's Avatar
Phil i have a question on the window net isent it suposed to be mounted to the inside of the bar i thought it was illegal to be on the outside?
George
Old 09-04-2007, 07:12 PM
  #85
7 Second Club
George
With the position of the driver seat, mount and latch its legal. The tech that looked at it said it was fine, the latch basically pulls it so its on the middle of the pipe.
Old 09-06-2007, 09:24 PM
  #86
7 Second Club
Picked the motor up today and got it ready to be assembled. Didn't get much time to work but got a couple of small things tightened up.
ETP LS7 - Machined for 1/2" and 3/8" head studs
LS7 top shot
LSx block with 1/2" && 3/8" head studs - still need to install 18 more head studs
O-ring
O-ring 2
Head studs of death
How do you torque these f*ckers
Outside studs
Hollowed B pillar
Start of lightening
Old 09-06-2007, 10:10 PM
  #87
NA$TY-TA's Avatar
Looks bad *** Phil.
You doing final assembly of the bottom end???
Old 09-07-2007, 08:17 AM
  #88
7 Second Club
Originally Posted by NA$TY-TA
Looks bad *** Phil.
Yeah, Rods and mains had to be loosened up alittle. Rings are ready to go except for #8-2nd ring was cut too big. I'm gonna hang the rods tonight and maybe get a couple in.
Phil
Old 09-07-2007, 01:29 PM
  #89
JUICED96Z's Avatar
Get a crows foot on those hard ones to torque but remember if the crows foot is straight out and not at a 90 degree angle on the torque wrench it adds like 10% to the torque number.
Old 09-07-2007, 03:53 PM
  #90
02Z28's Avatar
Badass build up man! Really good work.
Old 09-11-2007, 09:02 AM
  #91
7 Second Club
Got the mounts finished up for the vacuum pump and the fuel pump this morning before work.
Old 09-11-2007, 04:26 PM
  #92
NA$TY-TA's Avatar
Awsome Progress Phil.
You going to use Male -20 fittings of the water pump and run them that way or Reg Rad. Hose??
Kyle
Old 09-11-2007, 04:36 PM
  #93
7 Second Club
Kyle
Thanks kyle, I've got standard 1.5" threaded inlet and outlet I am going to swap on the radiator. The top is a threaded fitting so its a piece of cake to switch. The bottom is going to be cut off and I'll reweld it. I've got 1.5" SS tubing to use between the radiator and water pump. I'm still debating meziere water pump and possibly a remote water pump.
Phil
Old 09-13-2007, 02:22 PM
  #94
7 Second Club
Progress on turbo crossover tube, done. I'm heading back out to work on the wastegate locations.
1
2
3
4
5
6
7
8
9
Old 09-13-2007, 02:27 PM
  #95
LS1TECH Sponsor
ALLBOTTLE's Avatar
Looks crazy Phil!
You have to be getting excited... like a kid on Christmas morning.
Old 09-13-2007, 04:35 PM
  #96
kp
kp's Avatar
Thats really coming along well, nice looking work man
Old 09-13-2007, 05:15 PM
  #97
9sec93's Avatar
im lovin it. it looks clean and well thought out. actually gives me motivation to start workin on my car again. thanks
Old 09-13-2007, 06:29 PM
  #98
7 Second Club
I'm not really feelin the wastegate placement but its the only way to mount them.
Old 09-13-2007, 06:33 PM
  #99
LS1TECH Sponsor
ALLBOTTLE's Avatar
That looks like it will work well....
Old 09-14-2007, 08:00 AM
  #100
MrDude_1's Avatar
is there any reason you cant have the wastegates upside down, so they're "underneath" the pipes and out of the way?
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
