Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 09-30-2008, 02:06 AM
  #1261
bluecamaroz28's Avatar
Originally Posted by Phil99vette
We're going to throw the LSx back together, mock it up on the engine dyno, make 50 pulls @ 2000+hp, tear it down. If we can get it to live we'll throw it back in the Mustang, if not we'll part it out and build a 550+ BBC. My old gears were 3.50s new ones are alittle bigger.
Why waste it on the dyno. Run it for some good races then check it later. Just a thought.
How are the stang guys, that run 7.5, doing with their Ford engines? How different are those from LSX issues?
Old 09-30-2008, 08:58 PM
  #1262
Shawn @ VA Speed's Avatar
It's alot easier to see a problem before something bad happens in a controlled enviroment with lots of sensors than it is in a race car at the track.
Old 10-01-2008, 09:17 AM
  #1263
7 Second Club
ty_ty13's Avatar
you'll splinter that standard gear pretty quick... i'd keep looking while the car is running...
if you can find 2-3 other guys that need want the same gear you can have them custom made but you have to order a minimum of like 30 sets... just a thought...
Last edited by ty_ty13; 10-01-2008 at 11:51 AM. Reason: spelling..... dur deh duuuurrrr :(
Old 10-01-2008, 10:09 AM
  #1264
7 Second Club
Phil99vette's Avatar
How about the 9310 gears?
Old 10-01-2008, 11:09 AM
  #1265
if you can find 2-3 other guys that need want the same gear you can have them custom made but you have to order a minimum of like 30 sets... just a though...
Wolfe has been 7.30's on a std gear-we have been 7.50's on a std gear-i think it lasts longer than you think in a radial car
Old 10-01-2008, 11:51 AM
  #1266
7 Second Club
ty_ty13's Avatar
i forget that the problems we've had have been with a clutch car.... how many passes have you gotten from that gear? whats your weight and 60'?
Old 10-01-2008, 01:32 PM
  #1267
7 Second Club
3400 && 1.33s. Mine are coming out this week and we'll see how they look before I put a set of the 9310s in.
Old 10-01-2008, 01:33 PM
  #1268
7 Second Club
Oh and there are a couple cars sub 7.50s that are using standard ford 9" gears. Hinzman is using standard 8.8" gears.
Old 10-01-2008, 02:44 PM
  #1269
Race your car!
JL ws-6's Avatar
Sounds like changing the gear to get the RPM down is a possibility then As long as teh motor makes the power to get to the goal, if you can get the motor spinning 1000 rpm less then you are now it certainly may help/resolve the issue.
Old 10-01-2008, 03:48 PM
  #1270
we plan on running the same rpm range-just go faster thats all-looking for 205 or so
Old 10-01-2008, 05:26 PM
  #1271
Race your car!
JL ws-6's Avatar
Nevermind then LOL.
I figured with the gearing change, that if you could get the same speed with 1000 less rpm you'd be that much better off.
I didn't realize that you were on a mission to go that fast.
Old 10-01-2008, 05:53 PM
  #1272
7 Second Club
I've got F-n 200 on the brain. We may need to switch turbos to take advantage of the new motor. 114mm should do the trick.
Old 10-01-2008, 06:12 PM
  #1273
xfactor_pitbulls's Avatar
I thought you were going back the LSX route? 114mm huh..........****. Fill that ******* block and run it on alcohol. Quit pussyfooting around.
Does 114mm limit you on where you can run? Or is it generally just a single turbo rule of any size?
Old 10-01-2008, 06:54 PM
  #1274
1QuickT-A's Avatar
I say fill the block, do all the fancy machining and girdle stuff, put a 114mm on it and call Alan Dudley and try his MFI setup with some alchy!!! no water, no radiator, no fans, no i/c, no ****!
Old 10-01-2008, 08:06 PM
  #1275
were going LSX-we will pass on the alky,but any turbo is allowed on a small block.
If we go the alky route it would be with the bs3.
Old 10-02-2008, 04:40 AM
  #1276
Race your car!
JL ws-6's Avatar
BS3 cab run 2 sets of injectors, I can't imagine that 2 sets of 160 lb'ers wouldn't be enough if ya wanted to run alky.
I remember wormy having to adda 2nd set to their car because with the 114 mm they put on they actually ran out of fuel with the 160 lb'ers
Old 10-02-2008, 07:41 AM
  #1277
7 Second Club
Wormy needed a new fuel pump not more injectors.
Old 10-02-2008, 10:21 AM
  #1278
Race your car!
JL ws-6's Avatar
Not sure what it was he was doing, I just remember seeing the intake set up with a 2nd set of injectors on it, and I remember they were going to 2 fuel pumps instead of one, not sure if it was 2 seperate fuel systems or what, I didn't pay that close attenion, I'm so far away from needing anything like that it's a whole different realm then what I'm doing. I just remember reading it and thinking woah, how the hell can a set of 160's not be enough if you're still running race gas.... then I checked one of those injector calculator websites and figured he was trying to get enough fuel system for about 3000 hp.
**** I hope someday I can say I'm making 1/3 of that LOL
Old 10-02-2008, 10:53 AM
  #1279
yeah,there is no reason for more than 1 set of 160's in a small block-can easily make 2800hp with those-have to run alot of rail pressure but still it's no problem
Old 10-02-2008, 11:10 AM
  #1280
Race your car!
JL ws-6's Avatar
That's what I always thought, that a set of 160's was good for as much power as a small block was really capable of producing.
Not sure why they were going to a 2nd set... they were putting a 2nd set on at one point yes?
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
