SFI 25.2 Mustang/LSx build "The Renegade"
#141
I didn't get much done yesterday. I had a corvette to install some headers + mid section and a vararam. Got most of it done, needed to order some o2 extension harness's.
We worked on the dash(racepak) for a hour and got it very close to the final panel. Took an hour for lunch and came back to work on the motor plate. I welded the -16 bungs on the motor plate only to find another problem. With the size of the -16 fittings we can't run the alternator up top, no way to get the belt around the fittings.
Ken came over with his Trans-camaro-bird and we did some tuning on the juice last night found out he was pig rich on the kick, he pegged my wideband 10.0:1 or richer.
Got back to the garage and I did some work on the alternator mount. I'm going to try and mount it under the fuel pump which should work. It puts the alternator right infront of the steering rack and .500" above the K-member. I made the adjuster/c bracket that fits around the alternator and a spacer so it sits flat on the adjuster. This weekend I'll work on mounting that piece onto the motor plate.
#142
#144
My buddy brian came over today to help me get a few small projects knocked out. Here's what we got done:
New Powerglide in car, panels are clearanced
Shifter + linkage is setup - done
Transmount is done
Remote cutoff switch mounted + guide bar done
Front A-Arms - brace + final welding/fitment
Travel limiters adjusted for 2.5" travel short side 4" long side
Clearanced for coilovers
water pump for IC is ready to go in once I get some more steel
Pulled fenders, my dad is going to pick them up to start the body work
http://home.comcast.net/~7secStang/IMG_0402.JPG[/img]
![](http://home.comcast.net/~7secStang/IMG_0403.JPG)
Transmount is done
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#146
Didn't get much done today, got the rest of the -16 fittings. Ended up finding them for 14 each and found enough -16 hose to do the system for $20 from a local suppler that had a 6 foot section left over. Got the Meziere water pump mounted up and the supply line started, its a 1 7/8" tube. Also picked up the correct size belt for the alternator.
![](http://www.gvr4.com/phil97svt/IMG_0425.JPG)
![](http://www.gvr4.com/phil97svt/IMG_0426.JPG)
![](http://www.gvr4.com/phil97svt/IMG_0427.JPG)
#150
Parts man parts still waiting on my engine parts. I will be putting my trans and rear back in probily next weekend maybe monday night if I feel up to it. My car is easy install motor just add spray all done. Not the crazy combo you got going on good but crazy love it man keep up the good work. Glad to see another guy doing his own work not just paying a shop to do it. Not only could I not afford to pay a shop to do it there is no sence of accomplishment at the end if you payed someone to do it.
Have fun man,
George
Have fun man,
George
#154
Knocked out a couple of projects today.
- Wastegate dump tubes
- IAT bung
- WIdeband Bung
- Throttle cable bracket
- Racepak mount
- Vacuum pump bung
- Radiator 100% done welded second -16 bung onto inlet tank
Wideband bung
![](http://www.gvr4.com/phil97svt/IMG_0441.JPG)
Shortened downpipe - still needs to be cut 3-4" and get a 5" v-band into a 18" section of MS 5" tubing and will transition to 5" aluminum tube
![](http://www.gvr4.com/phil97svt/IMG_0442.JPG)
![](http://www.gvr4.com/phil97svt/IMG_0443.JPG)
Wastegate dumps
![](http://www.gvr4.com/phil97svt/IMG_0444.JPG)
Wastegate dumps bottom
![](http://www.gvr4.com/phil97svt/IMG_0445.JPG)
![](http://www.gvr4.com/phil97svt/IMG_0446.JPG)
Vacuum Pump to valley cover
![](http://www.gvr4.com/phil97svt/IMG_0447.JPG)
Throttle Pull
![](http://www.gvr4.com/phil97svt/IMG_0448.JPG)
Upper IC pipe with IAT
![](http://www.gvr4.com/phil97svt/IMG_0450.JPG)
IAT location
![](http://www.gvr4.com/phil97svt/IMG_0451.JPG)
Zoom IAT location
![](http://www.gvr4.com/phil97svt/IMG_0452.JPG)
Racepak
- IAT bung
- WIdeband Bung
- Racepak mount
- Vacuum pump bung
Wideband bung
Wastegate dumps
Throttle Pull
IAT location
Zoom IAT location
Racepak
#156
Bad *** Phil. It was a Nice Day yesterday and Budds Creek was hooking pretty well.
My Buddy's Diesel was even able to brake into the 14's LOL.
Its all good man im sure ill be back. We plan to do a rental in the spring for some testing of mine and the Outlaw car.
Ill let ya know.
Kyle
Ill let ya know.
Kyle
#158
Here is the one im looking at Phil. I know there not a Sponsor, but none of our sponsors carry ANYTHING like this......and ya cant right click on the pics to post them up ![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
http://www.chiseledperformance.net/transcooler.htm
Kyle
Kyle
