Drag Racing Tech
What vacuum pump setup are you using?
Old Sep 27, 2007 | 10:41 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
What I like about the star pump is that you will most likely never outgrow it unless you build some 650+ci mountain motor.
the quaility is amazing so is the customer service.
You've already spent thousands on your setup whats another $200 for the best pump you can buy
Old Sep 28, 2007 | 12:54 AM
1fstGM's Avatar
Restricted User
I am only running my alternator and was also looking for a vacuum pump. I have motor plates. Has anyone set up a pump with something like this? I am also in the market for a vacuum pump right now. I was leaning towards the aerospace and then figuring it out from there as far as mounting. I have also been pondering if I can run it off of my ASP Pulley, where the A/C belt use to go. I think it is a 4 rib belt here.
Old Sep 28, 2007 | 08:39 AM
Phil99vette's Avatar
7 Second Club
Originally Posted by Dragaholic
According to Star's website, the Sportsman vaccum pump uses 3 vanes which doesn't require a regulator.
http://www.starvacuumpumps.com/viewP...=STR.04.01.000
Phil99vette, did you use the Sportsman or Standard pump?
Standard pump with built-in regulator.
Old Sep 28, 2007 | 08:48 AM
7 Second Club
I used:
Starr Standard Vacuum pump ~$500
Billet pulley ~$75 - you can save some money and go composite pulley
Rear mounting bracket ~$75
Jones Mandrel ~$125
3/4" Aluminum round bar: 10
Belt: 10
Fittings: 60
Hose: 20
Catch Can: 15
Old Sep 28, 2007 | 10:10 AM
1fstGM's Avatar
Restricted User
Originally Posted by Phil99vette
I used:
Jones Mandrel ~$125
Belt: 10
Fittings: 60
Hose: 20
Catch Can: 15
Running the alternator?
1fstGM's Avatar
Restricted User
I used:
Jones Mandrel ~$125
Belt: 10
Fittings: 60
Hose: 20
Catch Can: 15
Running the alternator? If so how dod you manage the belt?
Old Sep 28, 2007 | 10:22 AM
7 Second Club
Very creative mounting. The alternator is going right below the fuel pump. I've got 1/2" between the alternator and the bottom of the K-member. Its LOW. The belt has 3/4" of clearance between the fuel pump boss and the belt. I'll have pics of the finished mount this weekend.
Old Sep 29, 2007 | 01:32 AM
1fstGM's Avatar
Restricted User
Cool. Those pictures will sure be apprecited, I am sure.
Old Sep 29, 2007 | 08:19 AM
1QuickT-A's Avatar
Originally Posted by Six Speeds Inc.
You will have to redrill the bolt pattern on the drive manderal for the asp pulley. I think Tim Tosoto can get those drive mandrels made for the Asp pulleys.
Its no big deal to get a machine shop to fit the mandrel to the pulley.. I had a friend of mine do it at his shop here in Birmingham and only took a few minutes..
Old Sep 29, 2007 | 08:21 AM
1QuickT-A's Avatar
I have the Aerospace pump and I got the mounting brackets from Tim Tosto for pretty cheap I think. Everything went together with ease..
Old Sep 29, 2007 | 10:02 AM
James Montigny's Avatar
Is there a such thing as an electric pump?
It seems to me that it would be much easier to install.
(I've been considering something for my cammed LT1 setup)
Old Sep 29, 2007 | 07:29 PM
  #32
BLK02WS6's Avatar
I put my GZ Motorsports pump on yesterday and it is awesome - definitely needed the regulator! Put a guage on the crankcase and went up the street to set it - pulled over 15" on a hit of the throttle - adjusted it down to 12" with the regulator and I can feel a difference in the car for sure!
The kit is great - everything you need except a serpentine belt - have to get one an inch longer. Well thought out, great price, and simple to install - highly recommend it.
Old Sep 29, 2007 | 08:18 PM
  #33
Dragaholic's Avatar
9 Second Club NA
It does look like a nice kit AND LS specific. Anyone else running this kit?
http://www.gzmotorsports.com/LSXVPK.html
Old Sep 29, 2007 | 10:51 PM
  #34
1fstGM's Avatar
Restricted User
That kit is nice. I checked ot out also, but found out I could not run it because I was not going through all the stock pulleys. I think you have to have most of that stuff to run it. Please correct me if I am wrong.
Old Sep 30, 2007 | 12:16 AM
  #35
LC's Avatar
LC
That is what backed me up too.. seems that you have to run a stock WP or a "street" version electric WP so the main belt goes all the way up to the stock tensor...
Old Sep 30, 2007 | 08:34 AM
  #36
BLK02WS6's Avatar
That is true - for the LS kit, you have to be using the stock tensioner.
But GZ could surely come up with other ways to work a setup for you - they sell kits and parts for many different engine combinations and mountings.
Old Sep 30, 2007 | 09:23 AM
  #37
n2ojunkie's Avatar
I know I am no where near the HP of you guys but could the stock AIR pump be used? I have the APS TT kit and was just thinking of hooking the inlet side up as a vacume pump. Will this work? I know it wont be alot but its free and I was thinking it should help some.
Old Sep 30, 2007 | 11:34 AM
  #38
Dragaholic's Avatar
9 Second Club NA
I kept throwing belts, so I got rid of my tensioner. The only thing I have on a belt now is the alternator and the crank pulley. I made the alternator adjustable so that I can tighten the belt.
I would have to put the tensioner back on to run this system because the pulley goes in place of the stock tensioner pulley. I wonder if I put the stock tensioner back in its original place, that if it would rub on the race electric water pump.
The only other thing I can think of is to mount that small 14 tooth pulley to the crank or buy a mandrel. I don't know if there's a mandrel out there with the same tooth design as this kit.
Old Sep 30, 2007 | 11:38 AM
  #39
Dragaholic's Avatar
9 Second Club NA
n2ojunkie, I highly doubt it will work good enough. It won't be strong enough and you'll be lucky to pull 1 to 2".
Old Sep 30, 2007 | 12:26 PM
  #40
LC's Avatar
LC
my car is SI.. I just want one to see what the hell happens to a SI before i put a cam on it..
