What vacuum pump setup are you using?
So far I've found an Aerospace kit and Moroso. Thunder Racing also has a kit, but its electric. Has anyone used it before?
And only cause I'm feeling generous:
http://www.jonkaaseracingengines.com...vacuumpump.php
http://www.jonkaaseracingengines.com...ereg12hose.php
http://www.jonkaaseracingengines.com...ex12antank.php
http://www.jonkaaseracingengines.com...mpmounting.php
http://www.thunderracing.com/catalog...vid=3&pcid=313
http://quartermax.users21.edigita.co...D=996&catID=58
http://www.jegs.com/webapp/wcs/store...63340_-1_10477
Personally I have been looking around at this stuff as well.. and I am leaning towards an aerospace setup and adding a regulator like Ben suggested. It's making it's way onto my list for next year.
http://www.starvacuumpumps.com/viewP...=STR.04.01.000
Phil99vette, did you use the Sportsman or Standard pump?
Check Phils 7.50 mustang thread, i just purchased the pump and aluminum drivel pulley it comes with the mounting bracket.
Depending on where you are going to mount it you are going to have to get creative either with a motorplate of fab something to mount it on, i got my Mandrel and pulleys from Jones Racing, you are also going to need a ATI or Similar Dampener with the SBC Hub Bolt pattern.
you are going to need some sort of oil catchcan/breather/seperator. I'm using a Moroso unit but you can buy the star piece as well.
So are you saying that my ASP SFI approved crank pulley is gona have to go?
If you want a more user friendly setup, someone make a bracket to mount the Aerospace pump where the AC unit goes.
reason i went with star is that no one i have ever talked to have ever seen a broken Star Pump, when i called to see if i could get a rebuild kit because i got the urge take it apart to see it inside. They asked what the hell had happened because they have never had a failure (other then engine parts getting in when the motor lets go).
i have heard that they are the best from countless sources....
This setup is BAD *** compared to the crappy stuff Ive seen from moroso or aerospace...
http://www.gzmotorsports.com/LSXVPK.html
