Expected more from my ET Streets
MT ET Streets (17"). While I did see a lot better ET and MPH
my 60' times still sucked ***, 1.9 and 1.99 where I used to hit
2.1 - 2.0 with the street tires. The ET Streets don't spin -as-
badly but they were far from hooking.
I was expecting more of an improvement from the drag tires.
Yeah, the car is lowered and will never be great for launch,
but still.
I tried them at 30PSI and 25PSI with the 25PSI turning in a
worse 60' (not enough to judge by I think) and 1MPH less.
25PSI was a lot more "squirmy" down-track. I did brief
burnouts, maybe not enough cook time? Left at about 3000
RPM loaded up and just matted it at the light.
What are lowered cars on ET Streets seeing for 60' times?
Any tips on what kind of foreplay these tires like the best?
24-26 in ET Street Radials
A good Burn out and hit it hard.
Mind you its now REALLY cold, the track is at the point where it may not hook at all, depending on how much power your making.
Best 60' 1.69 which I hit consistently now ( the car is dead hooking the LS7 clutch is slipping and limiting me from deeper 60's not the tires)
I did this at 13-14 psi on a 5500 RPM launch after a five second burnout. Granted I'm on a manual. At 16psi or above or less burnout I was up in smoke with 1.9's. My friend runs the et street bias and also runs 13 psi and hits effortless 1.5 60's in his procharged ZO6
I should also note I am running sportlines with LCA relocation brackets on the lowest hole and even that was not enough LCA angle for me. After my first trip down we reviewed the footage and you could see the rear tucking up instantly so I swapped back into the rear a pair of stock height coils and although it made the car look ghey it worked and I began hooking.
Every car is different, some like some tires better then other and at diff PSI, thats why its called Testing and Tuning.
From looking at your setup your car seems more of a road handling car, I would possibly consider getting double adjustable shocks for the front and a single adjustable for the rear so you can tune them to daily drive, road race or drag race.
I would guess you're just not getting enough or quick enough weight transfer.
but still.
I didn't notice a great deal of difference. It was only after about 50
passes and about a year old that they started to hook giving me some
nice 60' then a year later there worn out.
Now if your talking about drag radials, I'd stick with the MT's. I'm not sure what pressure to run in them though...
