Photos of the rides
I think it's a chromoly PA racing front end, with what looks to be a copy of BMR's stands on it. When I put the motor in, it located the motor completely against the firewall. Oh well, I got a smoking deal on the K member, a arms, and steering set up. Just used motor plates and all is good. Madman torque arm and SJM chromoly control arms and phb, and a wolfe anti-roll bar. Going to be a carbed 406 SBC and a t400 with a brake.
What stuff are you going to put in your 406? My buddy is running a 406 it runs 9.70's on the motor so far but we still have some tuning to do, it's been 9.30's on a 100 shot, but we still haven't even touched the ladder bars yet.
Motor made 790 hp with 32* of timing N/A.
What rims and tires you going with? Going to mini tub or any custom fab work?
PS whats up with the dark blue k-member and arms?
Its just a pretty basic 406, 11:1, dart iron eagle platinum heads with 215cc runners, solid roller, victor jr, ect, ect. Should make 550 or so. I'm assuming that your friends 406 isn't running 23* heads?
I'll be using polished weld magnums. 15x10 in the rear and 1 piece magnums in the front.
The K member and A arms are actually purple, but I'll send them out to be changed to black before final assembly. They were just that color when i bought them
No we're running an 18* head.
Sounds like a cool set up.
It's ok if you like purple we won't tell anyone
My old carb setup was a 377 13-1 solid roller with afr 210 heads, super victor, holley hp 950, 4340 rods and crank with an annular fogger on it. I ran lower side of 10's on the motor 9.30 on juice.
Mine was way over tired though would have went a lot faster on a tire 5" narrower.
I'll get after the motor combo after this one lets go, the rest of the car is being built to basicly support an 8.50 capable motor and pass.
I know I had mine all welded up solid before I decided to take a step back and look
Mine needed to be offset to the right of the car a bit. How far over did you move yours over? I may have to do the same.
Appreciate the advice!
That's his page with his setup, it is 3100 with him in it, 2925 without.
Car looks very stock in appearance without a lot of noticeable weight reductions, if it had the back seat in it would look stock minus the front race seats.
