26" vs 28" vise versa
98 TA stock motor
Only mods are Borla catback, lid, and a 150 shot of n20. Everything is else is stock, 3.23 gear's. 50/50 setting comp enginering shocks.
I have a semi built A4 and 4000+k stall converter that I' going to swap this weeked. Don't know if it wiil take it out of it's powerband with the juice.
I've been running 18" 555R which don't hook, so it's time for new tires.
So I've been looking for MT ET street radial's and 15" prostar's. Was looking at either a 275/50/15 26", but there's another set of 15x10 with 325/50/15 28".
What are the pro's and con's of using either one of those tire's 26" vs 28" vise versa. What would each do for me? Will a 28" lower my rpm, be too much tire for my gear, etc??
So basically a 4k stall, 3.23 gears, and a 150 shot.
I guess I'm just trying to give my rear end the time of it's life next weekend.lol
I have ran a best of 12.2 @118 with a crappy 2.0 60' 1/8 mile was 8.089 @ 91.47 mph thorugh a stock a4 and converter with a 150 shot on 18's.
Thanks in advance to everyone.
Im running the 28 and its lowered my MPH significantly. I'll be going back to the 26in soon enough.
What if in the real near future I switch too a 3.73 or 3.90 gear, will a 28" give it some mph, cause the gear will also lose some won't it?
Any thought's on the 325/50/15 I think 28"x13.5, is it too much tire for me?
Thanks
What are your thought's of the 325/50/15 28" for my car? I'm probaly going to do the performance modding in June, typical HCI and juice.
Any more advice guy's?
Thanks
the ideal gear + tire height will reveal itself if you use one of the many online calculators to figure out what combination of tire and gear will bring the car through the traps at or slightly above your normal shift point. the idea is to find a solution that uses the entire useful power band of the engine in every gear you hit in the 1320'.
try this one with different tire and gear combinationas: http://www.f-body.org/gears/
but there's no reason you shouldn't be able to make a drag radial work with that set up. don't move up to a 27 or 28 inch tire unless you up that gear.
