- Camaro and Firebird Aftermarket Performance Modifications<br>Overview of popular modifications to customize your Camaro or Firebird.
"Weight Reduction List" Fully Updated!
I doing that and moving the computer inside, really frees up a bunch of space under the hood. Deleting a bunch of useless wires off of the interior body harness and engine harness. Knocked around 7-8lbs of wire out. Adding back in a 2 step and nitrous harness that will negate those gains.
No regrets, the top is easy to put up and down without it. Actually I can operate manually quicker than with the power. Only downside is you need to get out of the car.
. Great looking cat back just very heavy. Replaced it with a single Dynomax 17223 Ultra Flo muffler and turn down, kept the SLP over the axle pipe. Very happy with the fitment, sound and weight. Muffler was around 9-10lbs the piping was around 3-5lbs so around 15-20lbs savings all in all. Weighed my muffler with tips 33lbs. Last edited by jlrz28; Jul 25, 2017 at 10:04 AM.
Others have reported a fully loaded stock 2000 A4 SS with 3/4 tank of gas weighs 3513 without them in it.
Based on these weights I put on 821.1 lbs of stuff and took off 775 lbs of stuff for a difference of 46.1
3513 + 821.1 - 775 = 3559.1.... damn it.....one or more of these parts below are off by about 0.9 lbs LOL
3 gauge pillar pod 1
A arms Stock lower (pair) 48
A arms UMI 2305 lower (pair) 22
A arms Stock upper (pair) 13.6
A arms UMI 2311 upper (pair) 9
Additional wiring 5
Cat Kooks GE-307540 4
Catback: Muffler, Tailpipes & Over Axle Pipe and I pipe Stock 38
Catch can, Mighty mouse hoses, fittings 1
CME 6ldesigns valence 8
CME Exhaust tips and elbows 14
Cold air intake SSRA 1
Control Arm rear relocation brackets Spohn #210-S 16
Control arms rear UMI adj 2018-R (pair) 9
Control arms Stock rear lower (pair) 6
Cutouts DHM low profile 3" (pair) 10
Driveshaft PST aluminum 3.5 13
Driveshaft stock aluminum 13
EGR, air pump & hardware 15
Exhaust clamps walker 33272 (6) 8
Flexplate B&M-20340 7
Flexplate Stock 7
Glowshift gauges 7
Grill insert stock b
Grill insert Stull billet grille 36-0180 2
Headers factory manifolds (pair) 26
Headers Speed Engineering LS1 1 7/8" 25
K member Stock 57
K member UMI 2320 43.5
Line Lock SLP kit 2
MAF 1
Motor mounts 7-512 Prothane 3.5
Muffler magnaflow 14267 14
Muffler Magnaflow 14416 (pair) 18
N2O Outlet Dedicated Fuel Cell 00-12050 8
N2O outlet remote bottle opener 00-66000 3
N2O outlet spare tire location bottle mount bracket 00-33001 3
N2O Outlet stage 2 accessory package 00-69002 5
N2O Outlet GM 98-02 F-Body 92mm FAST Intake Plate System 35
Panhard bar #104 Adjustable Spohn 8
Panhard bar Stock 5
Rear end: Dana Strange S60 with 4.10 gears, s-trac, 35 spline 190
Rear end: stock 10 bolt 150
Spare tire and jack 37
Strut tower brace UMI 2005-R 5.5
Struts/springs: Stock rear coil spring (pair) 12
Struts/springs: Factory front (pair) 70
Struts/springs: Stock rear shocks (pair) 10
Struts/springs: Viking double adj coil over kit front A206-350K (pair) 22.5
Struts/springs: Viking double adj coil over kit rear C213-R, 14DP150 pair) 15.1
SubFrame Connectors SFC001 BMR Weld in 25
Sun visors pair 2
Sway bar Factory Rear and end links 12
Sway bar rear drag Spohn#921 30
Sway bar Front stock and end links 14
Switch panels 0.5
Torque Arm MWC Tunnel mount torque arm and 3.5 catback crossmemer 23
Torque arm stock and auto cross member 21
Trans cooler B&M 70264 0.5
Wheels 225/50/17 tires continental contipro SSR (pair) 50
Wheels 275/50/15 Mickey Thompson e.t. streets (pair) 62
Wheels Factory 17x9 and 245 tires x 4 200
Wheels Race Star 15x8 RCE-92-580250DP (5.25" backspacing) (pair) 30
Wheels Race Star 17x7 RCE-92-770247DP (4.0" backspacing) (pair) 42
Y pipe Stock w/1 cat 21
Y pipe TSP 25-TSPSSY 17
