Drag wheels > what do you think of ET difference?
My car is a H/C car and is pretty strong ... should be easy 11.9's next time out to the track on Nittos. MT Street DR's will be going on the rears of the new wheels and MT street radials on the fronts.
No grinding on a 15" set of wheels ... hopefully, they won't cost as much as Bogart D10's.
When was the last time your tranny got looked over?
As for the tranny, it was refreshed by Chuck Johnson @ FLT back in March and should be fine. The car is pretty much stick weight minus the front sway car, jack, rear seats, etc.
I believe I can easily pick up a good 1/2 second and 5-6 mph with these drag wheels and MT's. What are your thoughts?
If you go full slick in back I think you'd drop an easy tenth or more from the wheel/tire swap, and a mph or two.
I went 11.6@116 h/c back in the day in the Formy @ stock weight + drag wheels + ac and some weight out.
camaro went 10.92@122 @ 3350 raceweight so figure 11.3@118 more at stock weight which is about right.
So, dropping the equivalent of 300 lbs dead weight + gaining 2 tenths on ET time + better weight distribution ... shouldn't that equal about a .5-.6 gain? I was reading some other folks posted .5 tenths and better gains just from tire and wheel swap. Of course, this is the Wild West of Forums where anything goes and much of what you read is fluff.
Thanks for weighing in guys ... anyone else?
The new Greg Weld wheels sure are nice, though ... thought going from 17" stockers to 15" drag wheels, skinnies, tires would have gained me more than .1-1.5. Oh well, the addiction continues.
Also keep in mind that 60 foot times aren't going to be tied to your wheel choice but traction which has a better chance on a 15" wheel versus a 17" wheel due to the increased sidewall help.
Derek
I've lost 25 lbs and made a few other simple changes (for the top end) since then. So, I'll breaks 11's next time out (this week?) ... getting a couple of MT street DR's for the rears. That alone should allow easy 1.6x 60's .... hoping for 1.5x.
My 1.70 60 ft was on 315/35R/17 MT Street DR'S with 35mm front bar on and connected I have only launched as high as 1800 rpm because I kept breaking the tires loose. Come to find out when Mike Norris did my AR header last month, my Adj TA was set to zero and the LCA's were at the highest holes on the relo brackets.
Last time out, I was on 275/40R/Nitto's and pulled a 1.768 60' ... only launching at about 1600 .... afraid I'd spin ... got my best MPH and ET to date. And I could tell (with the new -1.5 pinion angle setting, lowest relo bracket hole setting for the LCA's, and front bar removal) the car was planting the tires solid ... FINALLY!!!
When I go back out this week, weather permitting, I'll get behind some big slick cars and launch at a higher rpm and then I should be getitng the car into 1.6's and 11's pretty easily.
Once I get the 275 MT Street DR's from JEG's, I should be achieving 1.5x's or better. A lot of that depends on practicing my launches since I'm new at drag racing. I don't think my MPH will improve much, though ... maybe 116-117 at most ... at least until more weight comes off the car.
As soon as I get the camera software I bought off Ebay,
I'll post up some pics of the 'ram air' improvements I made this week to the car. I'm sure people who read this will think, 'yeah, another ram air preacher who should know ram air is worth nearly nothing'. But, I know ram air is not worth much and ONLY when the airbox is sealed well. However, I'll just say I wasn't afraid to use a dremmel tool on the front underside nose of the hood ... also stuck a Fast Toys JAAM plate and their 85mm airlid on my FAST90/Holley90/SLP85/setup. Without someone going FI, I don't think there's a car out there which will have a better air charge being forced into their intake. It should be good for something ... if not, well, I'll at least say I cut oue a few ounces of fiberglass form the nose and have eyeballs on the underside of the hood ...
