Lingenfelter Launch Control (2-step)
and is this a soft rev limiter ( kinda like on a deisel - tach just stays put and not bounce around??)
Ray T
http://northshoremusclecars.vidiac.c...6a00fc4fc1.htm
Ray T
why would you want the line lock on while the trans break is?
dosen't make sense to me
Ray T
With the master switch off it will never activate, with it on it will when the brake is applied and I try to rev past my launch RPM it activates. I don't have a line lock yet so I roll into the burnout box and make sure the switch is off, foot brake my burnout, and during my walk up to the line I flip the 2-step toggle on, light the first stage light, bring it up on the 2-step, slowly lift the brake enough to creep into the second bulb, then just lift my foot off the brake when the tree drops and off I go...
Ideally I want to put one of these on my car, but have it activated by the transbrake button like the brake and the nitrous disable is so that way everything's normal unless the button for the brake/2 step is on.
Can it be wired that way? I sent the wiring diagram to the guy @ lingenfelter but I never heard back form him to see if it would work that way.
can it be wired to the clutch pedal like the circuit that allows you to turn the car on only fater the clutch is fully depressed?
I dont push the clutch to the floor when I shift down track, so Im not worried about it kicking in on the shift.
People who have back orders for the existing design will automatically get upgraded to the new design at no extra cost (the old price). The new launch controllers will be a little more expensive ($274.95 vs $249.95).
The new features include:
- custom molded low profile glass filled Nylon case for much higher temperature resistance and access to the adjust settings without having to remove the case cover
- dedicated timing retard trigger wire so you can activate the launch controller via 12vdc or ground and still use the timing retard feature
- a 3 bar MAP sensor input harness and boost based timing retard adjustments
- timing retard rate adjustment (for nitrous applications)
- an analog voltage output wire so you can output the timing retard from our controller to EFILive, HPTuners, DashDAQ, etc.
- increased timing retard authority (compared to the LNC-001R)
I will get better pictures and a more complete description posted in the next couple of days.
We should have them up on the web site and eBay store in a couple of days as well. The LNC-001R is still on the web site but we are out of them so if you order the LNC-001R you will really get an LNC-002. We took them off the eBay store but they should be back up in a couple of days.
The biggest delay will probably be me getting the updated instructions done.
