Lingenfelter Launch Control (2-step)
People who have back orders for the existing design will automatically get upgraded to the new design at no extra cost (the old price). The new launch controllers will be a little more expensive ($274.95 vs $249.95).
The new features include:
- custom molded low profile glass filled Nylon case for much higher temperature resistance and access to the adjust settings without having to remove the case cover
- dedicated timing retard trigger wire so you can activate the launch controller via 12vdc or ground and still use the timing retard feature
- a 3 bar MAP sensor input harness and boost based timing retard adjustments
- timing retard rate adjustment (for nitrous applications)
- an analog voltage output wire so you can output the timing retard from our controller to EFILive, HPTuners, DashDAQ, etc.
- increased timing retard authority (compared to the LNC-001R)
I will get better pictures and a more complete description posted in the next couple of days.
We should have them up on the web site and eBay store in a couple of days as well. The LNC-001R is still on the web site but we are out of them so if you order the LNC-001R you will really get an LNC-002. We took them off the eBay store but they should be back up in a couple of days.
The biggest delay will probably be me getting the updated instructions done.
I spoke with you at the end of last week about hooking this up with my T-brake and getting voltage feedback in the circuit.
Well I sent it back to you just yesterday, so is there anyway that I can upgrade to the new unit?
I will give you a call in regards to this later in the week.
Any help would be appreciated.
Thanks,
Justin
I will look into this further but I think it would be more cost effective for customers to sell the LNC-001R as a used unit and then purchase the LNC-002.
Jason
Thanks,
Justin
P.S. I'm running it with MSD Coils
-Dave
The new instructions are done and as soon as they are on the web site, I will post a link to them.
Here is a link to the instructions:
http://www.lingenfelter.com/document...rollerv1.0.pdf
If you have any questions, comments, suggestions, feedback etc. after reading the instructions, contact me.
I noticed the diagrams still reference LNC-001
The wiring differences are the added wires for the analog voltage output, the MAP sensor input and the dedicated timing retard trigger wire. The RPM limit activation wires are the same as are the coil pack connections. The wires are labeled on the LNC-002 label and are described in the instructions.
Im gonna throw in my 2 step just got it. Thanks LPE!
What settings should i start with? should i not touch timing, and see how much boost it builds and 3k and go up? see how the car launches and play around or what? Thnaks in advance. Chris
