Drag Racing Tech
Lingenfelter Launch Control (2-step)
Old Sep 28, 2008 | 12:02 PM
  #101
Bluhaven's Avatar
That's sorta what we figured, we would try it and hopefully it would help with consistency, if it doesn't sell it and move on. Gotta try something, good luck.
Kevin
Old Sep 28, 2008 | 07:24 PM
  #102
CanuckSS's Avatar
I am looking for a used one when you are ready.
Thanks
Old Sep 28, 2008 | 10:34 PM
  #103
Jason Haines @ LPE's Avatar
LS1Tech Sponsor
Default FAST EFI with Lingenfelter launch controller
Sorry but we haven't tested any of the aftermarket engine management systems that use the production coils with our launch controller.
Most of them have built in 2-step capability already.
Originally Posted by protracracing
Can the LNC-002 be used with a classic Fast EFI system set up for an ls1 ?
Thank
Dennis
Old Sep 28, 2008 | 10:53 PM
  #104
LS1Tech Sponsor
Default Low rpm 2-step launch settings
We have a lot of customers that run fairly low launch rpm settings (1800 to 2500) with the 2-step. We actually changed the minimum RPM settng on our early LNC-001 launch controllers because people asked for RPM settings below 2000 rpm.
Originally Posted by REDGAR
what rpm you set it to? Mine is not doing what I want. at 2100 the car is making slow hard raps rocking the car making it impossible to focus on the the light
Old Nov 24, 2008 | 10:25 AM
  #105
1INSANEGTO's Avatar
Has anyone used this on a nitrous auto car?
I am asking because I wanna use this on a nitrous 4L60E car. Converting to a transbrake is to much for my taste so this would be a easy fix.
Car starts to push through while stalling up about 2700rpm. (3200 stall) I wanna stick this at 2600rpms and not have to worry about watching the light and rpm. For the nitrous we have the NOS LCD touch screen nitrous timer set at 3,000rpm engauge.
Before we had to mess with timing to comp for the nitrous and now it seems that now we can tune the best we can N/A and once this 2step is turned on we can do the timing thing.
Old Nov 24, 2008 | 10:36 AM
  #106
Turbo LS1 SS's Avatar
Originally Posted by Jason Haines @ LPE
We are considering producing a version of the LNC-002 that would have a high and low RPM setting (a true 2-step) but then it wouldn't have the timing retard features (we don't have enough inputs in the current circuit board design to do all three in one device).
any news on this?
im definitely considering running a two step (M6 S88 turbo car, want to start to make a run at the track)...
what would be more beneficial in your opinion? true 2-step and "retardability"
Old Nov 24, 2008 | 12:38 PM
  #107
tee-boy's Avatar
Default ddfdfdf
Originally Posted by MetallicaMatt
I have an M6 but I am thinking of installing a master arm switch, and a push button switch I can keep my finger on while in first gear, so when I pull back for second, the "launch rev limiter" feature shuts off and I'm headed down the track with the juice
thats if I can keep my finger on the button launching with the juice!
This is what i wound up doing. master toggle controls line lock and 2 step. when closed, the 2 step then has to go through a momentary switch and then an additional clutch position switch. No relays involved due to 2 clutch position switches.
Old Nov 24, 2008 | 10:50 PM
  #108
LS1Tech Sponsor
Default "True 2-step" version of LPE launch controller
We are building around 10 of the LNC-003 launch controllers that will have two RPM limit settings but no timing retard function. We should probably have these done right after Thanksgiving. If they sell, we will make more.
What is more beneficial depends on if you need the timing retard feature or not and if you need the two different RPM setting functions.
Originally Posted by Turbo LS1 SS
any news on this?
Last edited by Jason Haines @ LPE; Nov 24, 2008 at 10:51 PM. Reason: Left out info on expected completion time.
Old Nov 25, 2008 | 01:22 PM
  #109
ujslost2's Avatar
So would this be considered a 3 step? If so how much?
Old Nov 25, 2008 | 01:43 PM
  #110
LS1Tech Sponsor
Default 2-step, 3-step etc
Our LNC-001R and the LNC-002 are really just single RPM setting control devices (1-steps) but are often referred to as 2-steps since the factory ECM/PCM acts as the 1st RPM step/set point and the launch controller becomes the second.
The LNC-003 actually has two independent RPM switch points so it would be a "true" 2-step.
Since the LNC-003 won't have the MAP sensor connector harness it will be a little cheaper than the LNC-002 (probably $10 less or so).
Old Nov 25, 2008 | 03:15 PM
  #111
koolrayz's Avatar
I use the 4l60 with the transbrake and nitrous. I suggest using the transbrake signal to lock out the nitrous instead of relying on the windowswitch setting. You will want it to hit when the brake is released any
Using a low two step setting like your talking about and flashing into the converter with the progressive controller at a very low setting has worked very well for me. I LOVE my lingenfelter two step
Old Nov 25, 2008 | 06:02 PM
  #112
1BADAIR's Avatar
will the n20 deactivate when the clutch is pushed when shifting using the n20 deactivation feature? My trans is faceplated so I never lift
Old Nov 25, 2008 | 07:15 PM
  #113
tee-boy's Avatar
how many amps does the input circuity draw?
Old Nov 25, 2008 | 08:54 PM
  #114
LS1Tech Sponsor
Default Nitrous deactivation
I assume you are asking about the nitrous deactivation feature on the nitrous controller and not on the Lingenfelter LNC-001 or LNC-002 launch/timing retard controller because the LNC's don't have nitrous deactivation control features.
Old Nov 25, 2008 | 09:58 PM
  #115
cablebandit's Avatar
Jason, I heard that ls1 coilpacks trigger by ground but ls2 coilpacks trigger by voltage. I have a ls1 with ls2 coilpacks...Jerry Hunicutt here....thought I'd pass that "info" along
Lemme know once u get the lnc-03 ready for sale. You know I have been dying for one
Old Nov 25, 2008 | 10:09 PM
  #116
1BADAIR's Avatar
sorry. I didn't pay much attention to the wiring diagram for the nitrous disable relay
Old Nov 25, 2008 | 11:08 PM
  #117
Reject's Avatar
i'll get one when i get back, i just love how it sounds
Old Nov 26, 2008 | 08:01 PM
  #118
LS1Tech Sponsor
Default LNC-003 etc
The LNC-003's should be ready next week or the week after that.
I don't think that the trigger method is different between the different coil packs but I will do some checking on that.
Old Jan 12, 2009 | 06:38 AM
  #119
tee-boy's Avatar
Other than the unit being properly hooked up/wired in, what other parameters from the PCM need to be active for the Rev limiter to trigger?
For instance, does TPS need to be at 100 percent? Or maybe, does the PCM Rev limit need to be reached?
Old Jan 12, 2009 | 10:19 AM
  #120
tee-boy's Avatar
Default For sale
Originally Posted by Bluhaven
I've got an LNC-002 for sale. https://ls1tech.com/forums/western-c...-step-f-s.html
Kevin
wow, we can sell stuff in this forum now? nEWS TO ME.
