IHRA tracks require tranny blanket to run 10's?
I'm looking to run high 10's at an IHRA track and need to know if a transmission blanket is required. Also do they have the same roll bar padding rule as NHRA? I found a nice cheap roll bar pad in the color I want but it's not SFI approved.
Here is what I am buying/have so far:
SN2000 helmet
Single layer fire jacket
5 point harness
6 point roll bar
Driveshaft safety loop
Fire extinguisher
Tranny blanket???
SFI approved roll bar padding????
Anything else I am missing?
Any help would be greatly appreciated. I did a search but only got NHRA info.
SN2000 helmet
5 point harness
6 point roll bar
Fire extinguisher
Tranny blanket???
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
Try www.ihra.com I'd guess you'll need similar stuff to NHRA's 10 second rules but only way to know for sure is get a rulebook and/or check their site.
Derek
Derek
10.99 requires a tranny blanket, SFI balancer, aftermarket axles, and c clip eliminators.
The open ended lug applies to the rule of the stud penetrating 1/4 into the head of a shanked lug nut. The easiest way to identify that is to have an open ended lug nut.
I've never been hassled about SFI padding, but the rules say that if your head can hit it, it needs to be padded
Here ya go.
10.00-11.49
AXLES: Aftermarket axles and retention device mandatory
DRIVELINE: 1 Driveshaft loop mandatory
DRIVER RESTRAINT SYSTEM: Not Mandatory- If you have a 5 point it must be SFI 16.1 within 2 year cert
FIRE EXTINGUISHER: Mandatory--Must be properly secured
FLYWHEEL/CLUTCH: SFI 6.1 Flywheel Shield, and clutch, pressure plate, and flywheel meeting SFI 1.1
FLEXPLATE: Mandatory SFI 29.1 if vehicle exceeds 135 MPH
FUEL SYSTEM: All batteries, fuel lines, pumps or filler necks located in trunk must be isolated from driver's compartment
HARMONIC BALANCER: SFI 18.1 required on all vehicles running 10.99 or faster
HELMET: SN 95 or newer, or SFI 41.1A, 41.2A, 31.1A, or 31.2A
MASTER CUTOFF: Mandatory on relocated batteries
PROTECTIVE CLOTHING: Minimum SFI 3.2A-5 Jacket and 3.3-1 gloves if running nitrous
ROLL CAGE/ROLL BAR: Roll cage (8 point) mandatory required on all entries faster than 135 MPH. All other require a 5 or 6 point roll bar.Convertible running 10.99 and quicker require 8pt. cage
TRANNY SHIELD: SFI 4.1 required on all automatics running faster than 10.99
10.00-11.49
Wow. Thanks for the replies. I think I'll go to the track this weekend and talk to some of the 10 second guys and find out what they actually enforce at our track. I don't mind the little stuff but I wanted keep using my stock 10 bolt until it breaks.
Here you go. This is what's in the general safety area of the book.
9.99 and quicker:
AXLES: Aftermarket axles and retention device required (C-clip eliminators)
DRIVESHAFT LOOP: Required on all cars running 9.99 and quicker
DRIVER RESTRAINT SYSTEM: Mandatory SFI 16.1 within 2 year expiration date
FLEXPLATE AND SHIELD: SFI 29.1 flexplate and SFI 30.1 shield required
HARMONIC BALANCER: SFI 18.1 mandatory
HELMET: SN 95 and newer or SFI 31.1A, 31.2A, 41.1A, or 41.2A
PARACHUTE: Mandatory at 150 MPH
PROTECTIVE CLOTHING: 9.00 or quicker-SFI 3.2a Jacket and Pants, neck collar, and gloves
ROLL CAGE: Mandatory Faster than 9.0 must have chassis cert
TRANNY SHIELD: Mandatory SFI 4.1
11.50-13.49
DRIVESHAFT LOOP: Required on all vehicles using racing slicks
FENDERS: All fenders must be beaded or rolled if altered
FUEL SYSTEM: Lines must be routed outside of vehicle
HELMET: SN90 or newer
HOOD: Mandatory
MASTER CUTOFF: Required if battery relocated
ROLLBAR/CAGE: 6 point rollbar required on convertibles running 11.00-13.49. A cage is required on all entries running 135mph or faster.
STREET EQUIPMENT: One working taillight required
TRANNY SHIELD: Recommended for automatic vehicles to have blanket or shield meeting SFI 4.1
WINDSHIELD/WINDOWS: May be replaced with 1/8" Lexan. Must be clear except factory tinted glass. Windows must be closed during competition, but not required to be operational.
13.50 and Slower
BODY: Only full bodied vehicles
BRAKES: 4 wheel brakes mandatory
DRIVESHAFT LOOP: Mandatory on any vehicles using racing slicks
DRIVER: Must remain in stock location
EXHAUST SYSTEM: Headers permitted, must be designed to route exhaust gas away from car.
FIREWALL: OEM Type mandatory
FLOOR: Full floor mandatory
HOOD: Mandatory
ROLL BAR: Recommended
TRANSMISSION: Any OEM transmission allowed. Must have neutral safety switch
WHEELS AND TIRES: Must be automotive wheels suitable for street use. Racing slicks permitted. Motorcycle wheels prohibited. Minimum wheel size is 13". Recaps prohibited
9.99 and quicker:
11.50-13.49
HOOD: Mandatory
13.50 and Slower
HOOD: Mandatory
