Drag Racing Tech
SFC question
Old Jun 12, 2008 | 08:12 PM
chas010's Avatar
Default SFC question
Hi everyone, quick question here; How important are sub frame connectors?
I have a 1995 z28 stock suspension drag radial car running 11.6s at 116 1.65 60ft (pulls the drivers wheel a copuple of inches at the line) with no sfc. Are my doors gonna stop lining up soon?
thanks jason
Old Jun 12, 2008 | 09:10 PM
RAGENZ28's Avatar
Subframes help stiffen the chassis, if you're getting twist in the chassis invest in a good anti roll bar that will help a lot.
Old Jun 13, 2008 | 08:59 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
Hello, yes after a while you will start having alignment issues with your doors. Frame connectors will strengthen the chassis and make the car more consistant. As RAGEN said a good anti roll bar will help eliminate the body roll and we have one of the best on the market. If you have any questions please give us a call.Here is a link to our suspension page and a pic of our xtreme rear anti roll bar.
http://www.bmrfabrication.com/F-bodySuspension.htm
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jun 13, 2008 | 01:57 PM
1QuickT-A's Avatar
Yeah I would suggest you buy a set of SFC's from BMR and the anti-roll bar in the picture above.. I run nothing but BMR on my car and love it!
Old Jun 13, 2008 | 03:00 PM
BMR Tech2's Avatar
Talking
Thanks for the support!!
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old Jun 13, 2008 | 03:11 PM
daniel6718's Avatar
ive got a drag bar with no flex aparent...no alignment problems without sfc, but im about to do sfc
i wanted to do chromoly tubular but heard that after a friend installed them you can grab them and the flex with your weight on them...said only do squared ones????
madman told me bmr or wolfe ones...
Old Jun 13, 2008 | 03:40 PM
BMR Tech2's Avatar
The square tube design is a stronger better design. A square or boxed design will resist twisting more than a tubular. Make sure you use a weld in frame connector, bolt in connectors do not work as good unless you weld them in. Here is a link top our page and a pic of our boxed connectors. If you have a convertible it requires a different connector. the weld in SFC001 are $169.95 per pair and are in stock ready to ship.
http://www.bmrfabrication.com/F-bodyChassis.htm
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Old Jun 13, 2008 | 04:09 PM
RAGENZ28's Avatar
Not speaking in terms of subframe design or chassis flexing, but a round tube will resist twisting better, while a square tube will resist bending better assuming the tubing is the same size.
Old Jun 13, 2008 | 06:13 PM
studderin's Avatar
Dennis you see any problem with cutting the rear mount of the boxed, down like it is on the round SFC. Just having the outside LCA plate?
Old Jun 13, 2008 | 06:25 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Not required, but as mentioned above SFC are a good thing to add to your car with the power putting down and the fact the floorpan, rockers and roof are what's connecting the front to rear, and they can shift!
Derek
Old Jun 13, 2008 | 08:03 PM
chas010's Avatar
Alright thanks guys, BMR boxed it is. Dennis, I followed that link and was instantly drawn to that manual steering rack kit you guys have and now I must have it.
Old Jun 14, 2008 | 11:03 AM
mrdragster1970's Avatar
6 & 8 Second Club
Good decision. SFC should be one of the 1st mods before hitting track, especially if you added power or stickies.
Old Jun 14, 2008 | 12:43 PM
tektrans's Avatar
SFC also will keep your t tops from leaking from chassis shifting
Old Jun 14, 2008 | 01:02 PM
RevGTO's Avatar
Pontiacerator
I developed a nasty 9" crease down my right quarter panel from a launching - even at my modest power level. I got it worked out and installed boxed weld-ins, and it hasn't come back.
