driveshaft weights
driveshaft weights
i was wondering what the weight difference would be between a aluminum and chromoly driveshaft. I am wondering if it is worth the extra couple bucks to go aluminum.
my car weighed 2940 before the recent weight mods with an iron block. I am going for the stock internal record so every pound counts. i am hoping to have the car weigh in the 2750 area without a driver.
If you're going for a record, carbon fiber, if you want something that you can beat on for a long, long time a 3" moly or 3.5" moly (real tuff) will be the best bet in the long run.
I'd run the most durable shaft considering broken ones can crash your car or break a lot of parts, pinions, trans tail housings etc.
If you are capable of breaking a record every bit helps but I doubt that the drive shaft will be your record breaking factor.
Mine is a Denny's Nitrous ready Chromoly, It is 44 3/4 from the center of one U joint to the other, it has a yoke to fit a powerglide and all together it weighs 19 Lbs. (I just weighed it.)
Peace of mind is priceless.
I had a 4" aluminum and a Strange 3.5" CM, the aluminum was 5lbs lighter. Up to you if its worth it it but changing the driveshaft alone never made any measurable difference in ET/MPH. I noticed the weld around one of the yokes starting to crack and I **** canned the aluminum one, might have lasted 2 passes, may have lasted 2000. But being a member of the driveshaft through a rear slick at 150mph club years ago it wasnt worth taking a chance for me.
But with a stock engine the lighter shaft may make more of a difference and breaking one wont be an issue most likely..
