Got some parts!!!!
Thanks to Erik at HKE for the 396, Josh at KYTP for the S91 turbo, Cary and Craig at ETP for the heads, and Robert at Chiseled Performance for the IC.
Thanks to Chuck and Aaron in advance for all the work we will need to do to get this done.
Thanks to Nick and Dan for all their help setting the engine in.
Stay tuned as we start to get this up and running. We have a lot of work to fab the turbo setup and hope to have it somewhat done when the car goes to Memphis. (unfortunately it will be display only)
More Pics at:
http://upgradeadvantage.spaces.live.com/default.aspx
Gonna be a big investment that will take a while, but that's o.k, end result will be worth it
Or, do it like that kid refrutec is doing (look in the FI section) by mounting the blower on a big alum plate, like a 2nd motor plate. I will do it slightly different because I will do an a2w and put it on the floor in the passenger's side, face an elbow backwards towards the firewall and go thru the car like that, run the other pipe thru the hvac delete plate.
Still alot of ideas, I am wondering if I can take my motor, just put some 9 to 1 dish pistons in it and change the intake/camshaft, I don't see why I can't, probably be the easiest/most cost effective route.
I'm thinking (note, just thinking) the biggest f1 size procharger for a head unit. I can't imagine that won't be enough to get the car real close to the limit of what the motor will take and what the chassis cert is good for.
Plus I think the tuning is easier with a blower car, the boost is pretty much linear. By playing with the timing I should be able to pull power at the start of the run, then ramp it back in and then take a little away for the last couple hundred feet to help the thing live a little longer.
Again, just thinking. I figure 20 grand to do it. One thing is for sure, no more forgetting to turn the bottle on in the lanes again, wait until that episode of pinks allout air's, I'll be banging my head on the wall every time it's on
Mmhmm Boost
Really though, I should be able to buy one crank pulley and maybe a 2 or 3 blower pulley's and be o.k. One big one to get started with, one 3 or 4 teeth smaller to get the car going and maybe one a few less for the gusto runs.
But it's all just thoughts at this point.
I think we spent more time drinking and BSing than we did placing the motor in it's new home.
