What is it, what does it do, can it be removed???
What is this, what does it do, and can it be removed, if so how? I pulled most of the interior wiring when I pulled the airbags, HVAC, and Stereo last year. If I recall from back then, nothing ran to that box, I see for a fact that all the ABS stuff goes to it, what else? Does this control the VATS too? I would hate to go through stripping it out just to find it is needed even if only for 2-3 wires...
Anyone have experiance with what this is and if it only runs the ABS or if it can be pulled?
When I just crawled under there a few minutes ago to snap those pis I notices that I did already cut a few wires off leading to that box previously, you can see a white and a grey wire clipped in the pics, so I guess I was wrong about not finding anything that ran to it when I did the in car wiring last year...
I stil have to do what you're doing to the engine bay wiring... but I have a feeling it's all just gonna come out and what I want to keep will get rewired. Seems easier that way.
So far I think I pulled about 3-4 # of wire from under the hood, and need to fine a few vacuume caps or something to plug the holes in my intake from taking the Power MC off and the vacuum resevior. I unplugged this box and if the car starts and doesn't throw any serions codes then I will just keep it out, but I do wonder about those wires comming from ofer by the PCM, then again it could just be getting different signals like Speed, and ect from the PCM...
Anyone know? I guess I should pull out the wiring schematic soon too... LOL
where is the bcm located in a 2000 car?
i noticed from browsing you are posting on your build plans i saw some stuff that might help you out a bit . will post link in your other thread when found .
