Drag Racing Tech
*project* minor update
Old Nov 10, 2008 | 10:42 PM
  #41
JRracing's Avatar
It's looking pretty good.
Old Nov 11, 2008 | 12:24 PM
  #42
BlackScreaminMachine's Avatar
Internet Mechanic
Shaping up pretty nice!!
Old Nov 11, 2008 | 12:42 PM
  #43
ndfrsd6's Avatar
looks awesome any picks of the door now thats its done ?
Old Nov 11, 2008 | 02:02 PM
  #44
Camaro396's Avatar
Looks good man! Not too many in that color. Nice hood.
Old Nov 11, 2008 | 02:31 PM
  #45
wlsmoku's Avatar
thanks fellas - most appreciated. still looks like it belongs in a junk yard to me - looking forward to getting it wrapped up and back in paint!
and your right - only 95 z28's made in that color! thanks for the props on the hood but i'm sure your not bias hahaha. you get yours painted yet? seems a lot of peeps have this hood lately, but i've only seen one or two in color.
Old Nov 11, 2008 | 04:15 PM
  #46
Camaro396's Avatar
Nope haha, not painted yet. Maybe by spring haha.
Old Nov 11, 2008 | 08:00 PM
  #47
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Looks good update wise. I'm still deciding if I should use aluminum or moly tubing for the front end when I cut mine off. I'm still not sure yet. I'd like to see how much your's will weigh once you are done.
Old Dec 1, 2008 | 09:45 PM
  #48
wlsmoku's Avatar
latest update
gotta weld out some of the 1/2" round bar, and make some tabs for the radiator support as well as upper bumper cover and it's done
many thanks again 1cdub!
Old Dec 1, 2008 | 09:46 PM
  #49
wlsmoku's Avatar
it MIGHT be 10 lbs max. it's super light with .035 wall
Old Dec 1, 2008 | 10:04 PM
  #50
Josh@KY-Turbo's Avatar
Bad *** bro. My 99 Z28 is awaiting the same fate. I am going as light as I possibly can with that car. Gotta make room for the Turbo setup.
Old Dec 3, 2008 | 02:20 PM
  #51
OWN3D BY MY PROF!
That looks really, really, really good . I bought some aluminum flat bar a little while ago and it was about $80 for a couple pieces. I'm sure using moly will save me money also.
Old Dec 3, 2008 | 03:14 PM
  #52
firefighting1101's Avatar
thats freakin badass. i wish i had some fabrication experience and the ***** to chop up my car like that. would be badass to have a 2800lb f body, fantastic work btw
Old Dec 3, 2008 | 05:46 PM
  #53
Taubr Unit's Avatar
nice work! Do you have better/closer pics of how you cut out the whole windshield cowl and fender supports? Wanna do it to mine, just would like to see some pics while i have time before i do it. AND what all brackets did u cut out of the interior?
Old Dec 3, 2008 | 08:25 PM
  #54
TOSTO RACING's Avatar
Damn Jerry looks great!!
You aren't messing around bro!
Old Dec 4, 2008 | 08:35 AM
  #55
wlsmoku's Avatar
Thanks everyone - really appreciate it! again - def wouldn't have been possible without 1cdub's help - hes a genius when it comes to fab work.
I'll get more pics of the final fab work soon before paint goes on. still gotta order fasteners for the hood, and plate off the front of the fenders.
I'll snap some better pics for ya showing you what I cut off up front. on the interior, I cut out all the seatbelt brackets, rear seat brackets, rear arm rest brackets, and center console bracket. not a ton of weight to save in there - guessing 15-20lbs???
Old Dec 4, 2008 | 05:50 PM
  #56
Taubr Unit's Avatar
Now how did you get the interior brackets off? Did you cut them off then grind the weld down or use a spot weld drill bit or just drilled them straight through? Im just gonna go to town on mine here in a bit but would like to go into it with some light on the subjust, lol. That color is pretty sweet too, its like a custom painted OEM car! Nobody's gonna call you a "***" when the ****** is draggin bumper!! haha
Old Dec 4, 2008 | 06:49 PM
  #57
OWN3D BY MY PROF!
I used an air grinder with a cut off wheel on it. I started off trying to drill out all of the spot welds and about went insane. Afterwards I went back with a pair of pliers and used the grinder to cut the welds by holding the wheel parallel to the weld and coming down on it. I then pulled the rest of the tabs off with the pliers.
Old Dec 4, 2008 | 06:50 PM
  #58
Taubr Unit's Avatar
have some close up shots of the aftermath of the grinding?
Old Dec 8, 2008 | 09:05 PM
  #59
wlsmoku's Avatar
1cdub finished up the tabs for the front clip tonight and welded up all the 1/2" round tubing. still got some sheet metal work under the windshield, but other than that it's ready for grinding/body work. hoping to be ready for paint by xmas so I can do that while i'm on vac
all lines up very well
whats left to clean up:
gotta find some kind of trim for this piece of metal. this is just low pressure fuel line, but I want to find some kind of weather stripping
Old Dec 8, 2008 | 09:41 PM
  #60
ndfrsd6's Avatar
looks awesome ....great fabricating !
