Drag Racing Tech
*project* minor update
Old Dec 9, 2008 | 12:30 AM
  #61
Josh@KY-Turbo's Avatar
Looks awesome.
Old Dec 9, 2008 | 07:53 AM
  #62
Camaro396's Avatar
Looks great man!
Old Dec 9, 2008 | 08:01 AM
  #63
SIC LSX's Avatar
Originally Posted by a98ws6
10 point and get it over with. The VAMP people will want it wont they? Lookin good so far. Just need to ditch those Telstars for some Draglites or something?
why would he want to down grade? LOL
Old Dec 9, 2008 | 01:10 PM
  #64
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That looks really good. I like the fact that you used the stock radiator. Do you plan on using the stock fans? Does the bottom of the radiator move around any with it only being secured by the top section?
Old Dec 9, 2008 | 01:59 PM
  #65
Ericbigmac83's Avatar
Nice street car
I'd love to do that to mine
Old Dec 9, 2008 | 02:11 PM
  #66
SIC LSX's Avatar
im sure he is going to keep the stock fans!
Old Dec 9, 2008 | 02:23 PM
  #67
wlsmoku's Avatar
I am going to try to reuse them...just depends on clearance with the elec water pump and the front mount distributor setup. of course when i sold my wire harness, I forgot to cut the plug off...so now I need to hunt one down
bottom of the rad does not move at all - theres a couple notches in the factory rad that we utilized when building the supports - they rest right inside them comfortably, so there should be no moving around at all.
as always many thanks for the comments folks - very appreciated.
off too mock up the cowl plates tonight....gotta get that finished up this week!
Old Dec 10, 2008 | 11:45 AM
  #68
Gunnar's Avatar
Moderator
Love it, Jerry. Best looking purple car I've ever seen.
And I can't get enough of his fab work, the cage in dlove's car looks amazing.
Old Dec 12, 2008 | 11:11 PM
  #69
BIG_T's Avatar
hell ya jerry its coming along great
Old Dec 14, 2008 | 11:29 AM
  #70
Krazy98Z28's Avatar
looks great!
Old Dec 17, 2008 | 07:49 PM
  #71
SSPerformance's Avatar
any more support for the frotn headlighs besides just the top bracket?
Old Dec 18, 2008 | 11:23 AM
  #72
wlsmoku's Avatar
the bottom factory bracket will be fuctional - I bent it up and screwed it into the factory metal - looks like it belongs there.
Old Jan 26, 2009 | 02:30 AM
  #73
JasonWW's Avatar
Since you cut out the fresh air inlet at the cowl, can you tell me where the air goes? Is the firewall double walled or something? It's a mystery to me. I need to clean out all the leaves and crap but I don't know where they end up.
Enlighten us please.
Old Jan 26, 2009 | 11:26 AM
  #74
wlsmoku's Avatar
there is no air to get in there since the hood goes all the way back to the windshield.
btw - picked up a Percy rear pretinted glass, and will be going to get the front when it's avail. MAN this thing is LIGHT!!!
Old Jan 26, 2009 | 06:10 PM
  #75
a98ws6's Avatar
Jerry, let me know how the install goes on that Percy's window. Ive been looking into getting the clear version and having it tinted but I have heard you really should have a window installer put the new window in?
Old Jan 26, 2009 | 06:41 PM
  #76
wlsmoku's Avatar
they say that cause it's supposed to be easier (they have the correct primer, and sealer)
I may have a line on a guy to cut me a deal to install it, so I may just have it done. the window itself is 2nd to none....damn nice quality!
Old Jan 28, 2009 | 05:14 PM
  #77
a98ws6's Avatar
I need to come see it when you get it in. If its dark enough, I can go that route.
Old Jan 28, 2009 | 06:27 PM
  #78
pmbmax's Avatar
Have you ever put your fronts (wheels) on a set of scales? I have those same ones. I think i wont to go to Magums are somthing super lite but i like the way the telstars look. By the way bad *** build
Old Jan 28, 2009 | 09:46 PM
  #79
wlsmoku's Avatar
they are pretty much the heaviest skinny...EVER hahaha
thanks for the props - very appreciated
build update:
dzus fastner rails on, and all the holes drilled in hood. more firewall work, and then priming engine bay. lil slow lately - totally my fault.
probs with hood fitment.....after hrs of grinding the hood to get it to fit front to back and sit flush like it should, the sides of the hood have redonkulous gaps!
lost a bit of motivation after nobody offering good tech on how to properly add fiberglass to the edge of the hood and make it strong, so I'm setting it aside and going back to the metal work.
besides...I miss blowing black snot from the welding/grinding
sorry - no pics til its in primer
Old Jan 28, 2009 | 09:48 PM
  #80
wlsmoku's Avatar
it's only 30% tint...not real dark. I do however like that it shouldn't scratch since the tint is in the lexan itself.
I'll def letcha know when it's in man - your always welcome to a few of my adult sodas
