Thunder Racing Raptor cam #'s
Old 04-05-2009, 10:08 PM
  #61
BADSZ28's Avatar
One question about the tuning thus far. It was mentioned this car had vacuum on the runs. What was the MAP reading durring those runs? Where should it be?
Old 04-05-2009, 10:12 PM
  #62
00firehawk's Avatar
The map was fine, the vacum reading just said it needed more air than it was getting. Basiclly I am far from maxing out air that the heads and cam can take on. I don't have the spec's on what the map was reading handy, I'll have to catch up with my tuner to see if he has it.
Old 04-05-2009, 10:16 PM
  #63
BADSZ28's Avatar
MAP is the sensor for vacuum. I am currious what the readings were that made the tuner believe you were not getting enough air.
Old 04-05-2009, 10:23 PM
  #64
00firehawk's Avatar
The map was fine, the vacum reading just said it needed more air than it was getting. Basiclly I am far from maxing out air that the heads and cam can take on. I don't have the spec's on what the map was reading handy, I'll have to catch up with my tuner to see if he has it. Basiclly he said that I probably will not max out the air intake with out going force induction. I'm eventually going to go with a FAST 92/92
Old 04-06-2009, 01:38 AM
  #65
HaulinHawk's Avatar
Fast setup wil net u a good gain.119 mph traps is pretty stout first time out.Get a cheap used set of bigs n littles for the track an u will be knockin in the 10's.Congrats an have fun.
Old 04-06-2009, 03:30 AM
  #66
00firehawk's Avatar
With that trap speed plus spinning as much as i did, once i get traction i'm hopeing for low low 11's high 10's........... The power and speed is defiently there just have to get it all to the ground and quit wasteing it on rubber...lol
if you would have seen the passes you'd laugh your @ss off....... Just imagine being almost sideways the whole 100ft and then kicking sideways again in 2nd and 3rd gear
Old 04-20-2009, 10:04 PM
  #67
Fast Bird's Avatar
Hey i did see it, i was with the guy that had the black gto and the guy with the gt 500 at Evadel Tx.
Old 04-29-2009, 11:10 AM
  #68
T.A.WS6
Guest
Posts: n/a
those numbers are amazing, have a graph bro?
Old 06-29-2009, 07:42 PM
  #69
00firehawk's Avatar
I haven't been on in a while but for the question of how much vacum i was pulling.... It was 97 kpa
Old 07-15-2009, 11:09 PM
  #70
00firehawk's Avatar
https://ls1tech.com/forums/picture.p...ictureid=28539
Old 07-15-2009, 11:10 PM
  #71
00firehawk's Avatar
THIS IS THE LINK TO MY DYNO GRAPH FROM THE RAPTOR CAM SWAP..... SORRY IT TOOK SO LONG
Old 07-16-2009, 11:29 AM
  #72
Rob M's Avatar
Nice set up and No.'s! Cheers once again to factory heads. BTW who did the head work? Sorry if it was mentioned earlier i just didn' catch a name or shop that did the work.
Old 07-16-2009, 11:32 AM
  #73
00firehawk's Avatar
Wall 2 Wall heads in Baton Rouge did the head work
Old 07-16-2009, 04:19 PM
  #74
Johny GTO's Avatar
so you were shooting for 500rwhp, the guys building your setup said you would be pretty close to that, and you would up with 425rwhp??
ok
Old 07-16-2009, 05:35 PM
  #75
00firehawk's Avatar
It is still a working progress... that was the dyno sheet right after the cam swap
Old 07-16-2009, 10:19 PM
  #76
AINT SKEERED's Avatar
i dont think Geoff at EPS would have told you it would make 500. He told me he has never had a 500 hp stock bottom end car come through his shop. Other peoples near 500 hp cars made 469 or so on his dyno now and at Thunder.
Old 07-16-2009, 10:57 PM
  #77
00firehawk's Avatar
For one he never said it would do 500.... no one said it would do 500 but it is only a goal we are shooting for. realisticlly i'll get 470ish and I'll be happy with that. ever motor does something different so no one knows what they can get till its all said and done
Old 07-17-2009, 12:14 AM
  #78
elias_799's Avatar
Well i have some more #'s with my set up..... I went to the track today and exactly what i expected to happen did....lmao
i made 4 runs and they all were close to the same. I did a 13.10 @ 119mph...... Wtf? I spun damn near all the way down the track and barely got out of 3rd gear. I ran my car on street tires with very low air pressure, i tried every thing in the book and could not hook up. I expected that for the most part. I just figured i'd throw that info out there so a few of yall could get a good laugh............. You have to love the traction issues .....lmfao.
In the next week or so i plan on runing with sticky's so i should put up something good. I'll keep everyone informed!!
lol i did a 13.1 when my car was bone stock (139000 mile motor) with an auto. what tires do you have 245's ?
Old 07-17-2009, 05:35 PM
  #79
00firehawk's Avatar
yea, 245/45 R17
Old 07-17-2009, 08:41 PM
  #80
elias_799's Avatar
time for some 315's buddy.
Quick Reply: Thunder Racing Raptor cam #'s
