Got my TSP combo tuned.
Old Feb 26, 2009 | 06:28 PM
antonio84's Avatar
Default Got my TSP combo tuned.
Well i went to tsp today and got my combo tuned and the results are 393hp and 366tq idk if its me or should i have gotten more out of it. What do yall think?
Old Feb 26, 2009 | 06:51 PM
98RedBird's Avatar
That was with an unlocked converter I assume? Sounds low to me.
Old Feb 26, 2009 | 06:53 PM
tillery's Avatar
Not really. DTR is open this weekend. Take er out and see.
Old Feb 26, 2009 | 06:56 PM
tillery's Avatar
BTW, Whats your compression.
Old Feb 26, 2009 | 09:51 PM
antonio84's Avatar
yeah it was.
Old Feb 26, 2009 | 09:53 PM
antonio84's Avatar
if i remember correctly it should be 10:4 or 10:5 since the heads are not milled.
Old Feb 26, 2009 | 10:00 PM
stumprrp's Avatar
400 horse through an auto sounds great to me man
Old Feb 26, 2009 | 10:49 PM
'Trust''s Avatar
TQ seems pretty low. What are the specs on the cam? Those 3.73's are going to rob some too.
Old Feb 27, 2009 | 12:16 AM
JRC2000SS's Avatar
dont worry bout it dude... my numbers arent even better. i did 5.3 2.5's with torquer3 and only did 415! and did i forget 2 mention that i have an m6. i wana know if ne one else has bought these heads and put low numbers too?
Old Feb 27, 2009 | 12:22 AM
tillery's Avatar
with our alt. in west tx. its not that bad. dont be disapointed. give some miles on the combo. and retune as nessasary. take it to the track and see what she will do. im in a nbm ta. will hbelp if i can
Old Feb 27, 2009 | 06:22 AM
venom ws7's Avatar
With unmilled heads stall gears small cam and A4 I think those numbers are great.
take to the track you'll love it high mid 11s for sure.
Old Feb 27, 2009 | 07:51 AM
PewterScreaminMach's Avatar
Not too bad considering the auto, stall, and fairly mild cam. Actually, you put down almost the same number I do with my mild H/C setup. I put down 400/367 with 224/228 cam and LS6 heads. Only difference is I'm running through a heavy M6 drivetrain versus your fairly normal auto drivetrain, so they're probably evening each other out.
With your auto and stall, assuming full weight, you should hit mid 11s at 116 or so no problem if you're hooking up.
Old Feb 27, 2009 | 12:22 PM
antonio84's Avatar
Originally Posted by 'trust'
tq seems pretty low. What are the specs on the cam? Those 3.73's are going to rob some too.
228/228 588/588 112.
Old Feb 27, 2009 | 12:27 PM
antonio84's Avatar
my friend dynoed his car in san antonio and only made 410 and he has m6 with heads and cam (the cam is alittle bigger than the ms3).
Old Feb 27, 2009 | 01:25 PM
Johnnystock's Avatar
Good numbers for auto. Numbers dont tell the story; run it at the track and check the MPH.
Old Feb 27, 2009 | 01:38 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
Those are great numbers. Remember, it's a stalled auto and the makes the numbers look low. It will severely outperform a T56 car that makes the same numbers
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Feb 27, 2009 | 01:41 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
x3. She'll be a strong runner!
A few years ago, we had a stock bottom end H/C car that dyno'd 408rwhp through the heavy driveline it had....she ran a 10.5x@12X at sea level!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Feb 27, 2009 | 01:44 PM
It will severely outperform a T56 car with the same numbers ET-wise, but not trap-speed-wise, and certainly not cruising on the highway, for example. Just a thought.
Old Feb 27, 2009 | 02:57 PM
oneBADDz's Avatar
If you were talking about a 350rwhp auto beating a 400rwhp T56 car in the 1/4 mile you would be right in that the T56 would have higher trap mph, but when they make the same power at the wheels, that is not correct.
Lower HP autos can beat a higher hp T56 in the 1/4 and the T56 will be catching it because of greater HP at the wheels. But when they have the same RWHP, the T56 will not be gaining on the auto, that wouldn't make any sense since we are talking about rear wheel horsepower here.
Old Feb 27, 2009 | 03:59 PM
The difference is not in the rwhp but in the gearing of the transmission. The T56 car stays in it's powerband better than an A4 car and if both had an identical graph from the same dyno, same weight, chances are the M6 car will be trapping a higher speed. Not necessarily a lot higher, but why do you think the new Corvettes, G8s, and high end European sports car have all gone A6 (or more) over the past few years? The fact is if you keep the car in it's powerband for a longer amount of time, it will be faster.
