FAST EZ-efi results
Old Aug 12, 2009 | 12:15 PM
Dennis@SpectacleSolutions's Avatar
LS1Tech Sponsor
Default FAST EZ-efi results
This isnt an LSx but I thought I would show the gains made with the new FAST EZ-efi kit we installed on a customers 3rd gen.
This kit comes with the throttle body, fuel pump, regulator, PCM, wiring harness, wide band, fuel line, fittings, and some other misc parts.
The kit tunes itself. You just install it and drive the car.
The first pull you see on the graph is with the holley 650 carb. The last pull is the one we made after only a few minutes of drive time on the set up. As it learns over time I sure it will make even better power. Obviously this motor wasnt built for racing. Its just a very mild daily driver.
Old Aug 12, 2009 | 01:24 PM
Fbodyjunkie06's Avatar
WOW 60 ft. lbs. of tq. at 4k rpm increase is amazing! Now thats some sotp feeling tire frying power gains right there. I've been showing these ez-efi kits to my good friends that have carb set-ups on nicely built 350 and 400 sbc's. And they and me have been saying that they look over priced, that they like the ease of their carbs, the self tuning is prolly crappy, and that the gains would probably be minimal. But I'll say that after seeing this I will have to show them that this is the way to GO!!! Incredible. I bet you could see 100 ft. lb gains on a built motor and 50 hp+ gains.
Old Aug 12, 2009 | 04:22 PM
LS1Tech Sponsor
and I can price them out a kit if they are interested. they may not be as "overpriced" as they are thinking. If they are getting pricing off the FAST website, well....that price can definately be beaten.
and the tuning is spot on. we watched the meter during the dyno pulls and it was dead on 13.1
Old Aug 12, 2009 | 04:39 PM
Damian's Avatar
LSX Mechanic
Nice to see people still giving the 3rd gen respect. That's my next build for a personal project. 91-92Z w/ a LSX/T-56 conversion.
Nice job guys.
Old Aug 12, 2009 | 05:25 PM
The price I have seen in most mags is around 1300 for everything. I'm sure injector size will come into play for different engine specs. But if they were to buy the kit you would spec all that out correct?
Old Aug 12, 2009 | 06:02 PM
LS1Tech Sponsor
give me a part number on the kit you are talking about. we are obviously talking about two different kits because my cost on the kit we just installed was more than what you just posted.
30227-KIT is the system we installed on this car.
http://www.jegs.com/i/Comp%20Cams/24...0002/-1?CT=999
Old Aug 13, 2009 | 02:12 PM
ws6t3rror's Avatar
Does anyone have an idea when the dual tb setup is going to be available? I have a buddy that wants the setup but he wants it on top of his tunnel ram.
I am also curious how quickly the drivability and wot fuel came around. How is the cold start of the system?
I am a bit leery of systems that don't let you adjust them personally, I think adjustability is a GOOD thing not a negative (have done xfi and bs3). I'd like to see fast or somebody else post up a video of it being installed with a clear pcm and then let it warm up and make some dyno pulls with a/f graphs to show it coming around. Also wouldn't mind seeing some video of it learning as it was being driven. Not saying the system doesn't do what it says it will, and those videos would not be the flashiest but would certainly put me and others at ease. That way you know exactly what to expect.
Nice to finally get to talk to somebody who actually has one running though .
Old Aug 13, 2009 | 03:59 PM
LS1Tech Sponsor
cold start is perfect. hit the key for a split second and it fires right up with no throttle.
I may see if I can get the owner to take some video of it being driven and learning.
Old Aug 15, 2009 | 03:47 PM
Ramrod92's Avatar
Ron Turnpaugh, the head EZ-EFI engineer has a pair on a tunnel ram on his 78 vette. By the way, that's my third gen that Jeff is doing the install on. Man, what a differnce. I told him today that is how the car should have come from the factory. Here's a post on the Corvette forum with some pics of his setup.... http://forums.corvetteforum.com/c3-t...link-rear.html Here's a link with a few shots of the EZ unit on my Camaro.... http://www.thirdgen.org/techboard/df...st-ez-efi.html
Old Aug 15, 2009 | 07:39 PM
ws6t3rror's Avatar
Yeah, now I have guys coming out of the woodwork that actually have this system installed (all reports are amazing so far). I did get word back from Ron after I pm'ed him, looks like in a short time we will be a go to get it on the tunnel ram when its released. Hopefully she picks up drivability and power over the super vic and molested demon carb thats on top of it now.
Old Aug 19, 2009 | 08:57 AM
LS1Tech Sponsor
Im a big fan of demon carbs......
That said, Id almost bet my house that you will pick up plenty of both driveability and power.
I think out pricing on these kits is very competitive. If you hear of anyone looking at one, please have them contact us for pricing.
Thanks
Jeff
Old Aug 20, 2009 | 05:09 AM
LS1MCSS's Avatar
Jeff,
Do you have any idea what sort of horsepower this system will support?
Old Aug 20, 2009 | 05:26 AM
PREDATOR-Z's Avatar
In the mags it said 550hp and on the site it says 600hp.
Old Aug 20, 2009 | 07:09 AM
LS1Tech Sponsor
I would lean more towards the 550 number.
Old Aug 20, 2009 | 10:25 AM
ws6t3rror's Avatar
It will support over 600 if you bump the fuel pressure up. Unofficially I was told if you have a killer fuel pump that will support the volume necessary at 80 psi the injectors will do 88lb-hr. The pump that comes with the kit won't do that though. There is a video on youtube of the system running on a gm 572 crate making 630hp or so.
Old Aug 21, 2009 | 10:01 AM
LS1Tech Sponsor
I just got off the phone with Comp this morning and was told the kit will support 600. So I guess I was wrong on my earlier statement.
So my apologies. ws6t3rror is correct.
Old Aug 21, 2009 | 11:27 AM
PREDATOR-Z's Avatar
622Hp/643trq on 60 psi
Old Aug 26, 2009 | 09:09 PM
chevynation's Avatar
Oh my god. So you just slap one of these babies on any freaking motor and it tunes itself perfectly?! My mind is blown. I think might just rip the pcm out of my car (which is giving me some **** right now) and try one of these j/k
Old Aug 26, 2009 | 09:24 PM
What a/f ratio does it shoot for? My buddy has a 650 HP BBC in his boat and is very interested in one of these. Can the widebands work in a watercooled exhaust?
Old Aug 26, 2009 | 09:27 PM
ws6t3rror's Avatar
You can specify what air fuel it shoots for at cruise wot and idle. Above 50% throttle it goes in a straight line from whatever the cruise is to the wot ratio via linear interpolation.
