WTF is up?
Old Sep 5, 2009 | 04:10 PM
blackhawk98's Avatar
Default WTF is up?
whos dyno is right?....i dyno tuned my car at east tex muscle car in longview it put down 432hp and 380tq then went to another performance shop and he said hes never seen an ls1 dyno over 400 n/a so he strapped it down and it only put down 368hp and 340tq both on a dynojet
Old Sep 5, 2009 | 04:30 PM
kinglt-1's Avatar
That just goes to show ya why dynos are mainly a measurement for tuning...I had my 96 383 lt1 m6 car dynoed at a place and it only put down like 350whp(shorty headers and 90 degrees w/ 88% humidity in the dyno room did not help any lol). I added LT headers and retuned it, seemed to help alot, never went back to the dyno tho. It was beating cars making 50whp more, so I quit caring about dyno numbers!
here is a vid of me racing a bpu supra on race gas tune, 20psi boost. His setup is trapping around 118-120, putting down around 420-440whp.
http://s223.photobucket.com/albums/d...oeandmitch.flv
Old Sep 5, 2009 | 04:36 PM
Fatbum's Avatar
Well....what are your mods...how can you expect people to know what it is up without knowing your mods? If you have heads/cam/Intake Mani and then the second tuner you took it too needs to get his **** recalibrate.
Old Sep 5, 2009 | 04:44 PM
Ls6 Patriot performance heads
Torquer v2 cam
ss4000 yank converter
stock 10 bolt with 3.23
Ls6 Intake
Built Transmission
stage 3 shift kit
full exhaust
The second guy said he built a 6.0 h/c 6sp ls1 it put down the same
Old Sep 5, 2009 | 05:53 PM
edcmat-l1's Avatar
If that's the case, he hasn't seen very many LS vehicles at all.
Old Sep 5, 2009 | 08:29 PM
Omega Doom's Avatar
I think the 432rwhp numbers are more correct!
Old Sep 5, 2009 | 10:37 PM
VIPERKLR's Avatar
ive seen dynos off as much as 50 hp before nothing new
Old Sep 5, 2009 | 11:48 PM
MelScrilla's Avatar
heads cam car, the first dyno was right. That second guy is probably a ford or gen 1 , or just an LS1 hater.
Most LS1's cam only make about 400 rwhp with a fast and some heads your lookin at over 450. I hate misinformed people who think old stuff is the only way to go fast.
Old Sep 6, 2009 | 12:41 AM
JeaneZ28's Avatar
Thanks to the second guy there are a lot of people out their thinking something is wrong with there car.
Old Sep 15, 2009 | 09:22 PM
HTX's Avatar
HTX
every dyno is different. No such thing as a right one or wrong one.
The first dyno was likley a very generous one and the second wasnt.
Nothing new
Old Sep 15, 2009 | 11:59 PM
moeZ28's Avatar
Its an auto with a loose converter, low end heads, and a medium sized cam, I would say he is closer to the lower numbers. If it was a 6spd, probably the higher numbers. Were these dyno runs locked/unlocked, what gear did you make the pulls in, and did it downshift on the first dyno numbers? I wouldnt think you would see a stock cube, auto, loose converter, heads and cam car hit 430's....
Dynos are tuning tools...go to the track and see what she runs to get an idea of where you are at!!! All dynos are different!!
Old Sep 16, 2009 | 12:04 AM
they were all 3rd gear pulls im pretty sure the verter was locked.....2nd dyno wasnt a mustang dyno i asked the guy...idk
Old Sep 16, 2009 | 10:27 AM
moeZ28's Avatar
Just from what I have seen from some friends locally, if you put down 360's through an auto with a loose *** converter like that, you are making good power. One of my close friends around here had a built 408ci iron block motor and a 4L80e with a loose as converter, that put down 435 rwhp...ran 10.80's all motor around 3400 lbs...its all in the combo, not the dyno numbers!!
Old Sep 17, 2009 | 11:27 AM
What i dont get is the second guy with the lower hp reading built a 6.0 iron block out of a truck with head/cam 00 camaro it also put down 368 hp and it was a 6spd
