HR 2009 Cadillac CTS-V Pulley Swap/Tune/Headers x 2!
Closed ex-Sponsor Account
Within the last 2 weeks we have worked on 2 different 2009 A6 CTS-V's. These cars are a definately a sweet setup. Both of these cars came to us completely bone stock. The first one we installed a Lingenfelter pulley swap with their intake tube which still uses the stock air box. We installed a K&N filter at the same time. The car dynoed 466 rwhp 463 rwtq bone stock. Here are the results from this car, along with a few build pictures:
Completed after install and engine covers reinstalled.
On the dyno for tuning.
Supercharger pulley pinned. Lingenfelter wanted us to just brad over the end of the hole so the pin could not come out. We decided to make it look a bit nicer, so we drilled and tapped the pulley so that we could install a small set screw.
After install, before engine covers.
All completed, ready to go!
The second one that we did included the same mods above, but with the addition of Kooks full exhaust. This car was similar to the first as far as stock numbers goes. It started with 460 rwhp and 461 rwtq.
With the addition of the Longtubes and full exhaust, this car made about 1.5 pounds less boost than the other.
Here are a few pictures of its install along with a dyno graph:
Top of supercharger removed for Snout Pulley install.
Front snout removed.
Front snout removed from blower, before pulley swap.
This is where the rattle comes from on these new V's. The spring in the supercharger shaft coupler wears into the shaft. This one has worn pretty good. We replaced the sprung coupler with a solid one from Lingenfelter.
Kooks Tips look great!
Headers installed!
Kooks Rear section.
Here is a quick video while we were tuning on the dyno just for sound of the Kooks exhaust!
http://www.youtube.com/user/HeintzRa.../5/RJr1o_euQPg
Thanks for checking it out!
Zach
Headers installed!
Kooks Rear section.
Zach
Man, one of my favorite cars, and right at the top of my list for best daily driver!
Impressive numbers!
Question, you say: 'With the addition of the Longtubes and full exhaust, this car made about 1.5 pounds less boost than the other.' I'm not experienced with FI, but is the lower boost due to the increased scavaging from the combustion champer due to the headers? If so, wouldn't the supercharger STILL produce the same amount of boost, regardless of the exhaust? Please educate me. Thanks!
Impressive numbers!
Impressive numbers!
Impressive numbers!
For example, we recently finished a GTO with a F1A Procharger. After completion of the car, he decided that he wanted to switch his AFR 225s for a set of TEA/TFS 235s. Just because the heads were more free flowing, we lost about 3 lbs of boost even with the same pulley setup. We made the same power with the 235s at 14psi as we did with the AFR's at 17psi.
Zach
That was exactly my first thought, just like the 03-04 Cobras. I liked the one without headers better myself. It was nice and quiet until you hit the go pedal
With the addition of the headers, there is less back pressure in the exhaust system, therefore causing boost to decrease. Boost is a measure of restriction, and with the headers, there is less restriction.
Zach
Zach
And then you can say 'I beat you even with factory exhaust' too!
1 Post
Very nice gains. I think I'd rather go with the headers and use a different pully to recoup the lost boost from free flowing exhaust.
I certainly hope to run into one of these Caddies. Might be interesting?
Just wondering if you could overlay the two graphs to illustrate the differences better. Boosted motor same pully, headers vs stock
1 Post
I was having a disagreement with my c6 owner friend. He's got an 07 with an LPE Maggie setup. He claims he'll lose power due to lower boost. I contend that the header gain will be enough to offset the boost loss, and he can always change pullys to get that loss back and be even further ahead.
I also wanted to see the power difference at each rpm, purely for educational purposes. I wouldn't be hunting any CTS V's or anything in the near future
EDIT
Thanks for the overlay. Looks like the V with headers might be able to hang, but then again they are so heavy. I raced a V last year from about 100-??? I didn't let off until I saw the shift light in 5th LOL. He was so far back it wasn't even funny. Also he wouldn't pull up next to me anymore either. I am thinking he was bonestock, I'd like to run into both of these cars.
Great work !!! Any future mods on the horizon for either car owner, or too soon to tell?
If he wasn't, I will. I would be very interested in seeing an overlay graph of all the changes done less headers compared to all the changes done including the headers.
+1 you got it.
Zach
Thanks, Zach. How much difference in boost between the 2? I am getting ready to have mine modded and 1 of the things that I am planning on having done is the ceramic coated Kooks back to the factory muffs, and planning on running the factory muffs for the present.
