Got it dyno tuned at Speed inc & it went well.
Went to Speed inc and Jim Moran worked his magic on my C5 after the heads/cam etc install and we ended up with
453.19 Max hp & 393.49 Max torque naturally asspirated in which Jim/Larry said that was respectable for my car.
We ended up putting the 100hp N20 jets in it using the bottle pressure around 900psi, Nitro Daves progressive controller at 100%, with his 92mm spray ring/plate and to make a long story short the car didn't have enough fuel pump and went lean before we could go completely through all the rpm range but before he lifted about 6k it was at
504.37 Max hp & 444.10 Max torque so he thought with a bigger pump it'd be right on track. BTW, all this is ran through RPM's stage 3 diff with 3.90 gears and Larry mentioned that it'd be about 15hp more than dyno says due to the gearing.
Anyway, the car sounds awesome and runs good and glad I took it to Speed inc.
What do you guys think? Good/Bad?
if you give me the cc of the heads and gasket used I can tell you where you are...
nice setup...
Yep I totally agree! thanks to Speed inc and TEA for sure! you guys are awesome!
Hey Orangemagic, I'm assuming your going this Saturday? I plan to go but who knows what the weather will be like......... its rained every year they have the chassis certification so they never do the test and tune. If its nice we'll have to chat
