Cam only Dyno sheet M6
Old Apr 22, 2010 | 03:41 AM
sayed_000's Avatar
Exclamation Cam only Dyno sheet M6
Hello guys
just want to share my cam only dyno sheet ..
mod's:
230/236 112+2
PRC springs .600
ls6 oil pump
paceseter LTs
ORY no-cats
Flowmaster CB
17" heavy Zr1
4.10 ratio
+Hp tuner
Stock/untouched:
stock slipping clutch!!
stock ls1 intake
stock 853 heads
Stock Lid and GM filter .
Stock Throttle Body
stock pushrods and rockers ...etc
tep: 31°C and Humidity 70%
fuel: 95 octane
Sorry for the image Quality ..
and now i have so many new mods ! (listed on my signature ) .. hopping for good numbers after adding Heads and a tune ..
Old Apr 22, 2010 | 04:46 AM
same o'j's Avatar
nice number for stock setup except cam
Old Apr 22, 2010 | 05:50 AM
sayed_000's Avatar
thanks man
Old Apr 22, 2010 | 07:57 AM
MikeG's Avatar
Throw that clutch in and you'll see some real numbers.
Old Apr 22, 2010 | 09:10 AM
sayed_000's Avatar
already did
now i have monster stage 4 + low weight flywheel !!
Old Apr 22, 2010 | 06:45 PM
spdygon's Avatar
have you dyno the car with new clutch? # look a bit low for the bolt ons and cam with 410 gears.
my car has about the same bolt on without cam, 410 gears and it dyno at 351rwh.
Old Apr 23, 2010 | 06:18 AM
sayed_000's Avatar
no not yet ..
i have to wait until i get a good set of heads .
Old Apr 23, 2010 | 10:48 PM
WeathermanShawn's Avatar
Something seems odd about that dyno graph..Is it just my eyes or does the HP/TQ cross at 4750 RPMS?
It just seems a little low for a cam that big..Normally HP/TQ crosses at 5250 RPM. Again, sometimes these you charts will trick you, but if the x and y axis are off..
Maybe I am just losing it, but the graph does not seem to match the printed numbers. Am I reading this wrong?
Old Apr 23, 2010 | 10:53 PM
kinglt-1's Avatar
I agree with WeathermanShawn, that graph is not right... Hp and tq should cross at 5250.
Old Apr 23, 2010 | 11:00 PM
BlkBird2000's Avatar
Jeez. That is a poorly setup car!
Old Apr 23, 2010 | 11:09 PM
Look at the graph. the HP and TQ are not even on the graph.
Old Apr 23, 2010 | 11:10 PM
Because the HP and TQ are not equal? They have like a 50 hp/tq difference across the graph.
Old Apr 23, 2010 | 11:31 PM
Reaperchild's Avatar
Duude 1 thing I know about your Setup (BADLY TUNED) Period .... If i were you .... Get ur ECU/PCM to texas speed to tune it up for you ...... FOR ALL THE ABOVE COMMENT'S ... WE HAVEN;T SEEN A WELL TRAINED/STUDIED TUNER yet ... but Bahrain is working it's way up !!
Can't Wait To See you @ the Dyno =)
Old Apr 24, 2010 | 06:36 AM
sayed_000's Avatar
thanks for all your comments guys !!
i knew there is something wrong about the graph !!
Old Apr 24, 2010 | 09:30 AM
JPH's Avatar
JPH
I would say you need to do some AFR adjustment?
Old Apr 24, 2010 | 12:39 PM
WKMCD's Avatar
FWIW: I ran that cam on XE-R lobes in my 347. With good heads and ported 90/90 setup made 460-428 and was almost perfect driving. It's probably my favorite mid-size cam.
Old Apr 24, 2010 | 03:22 PM
kinglt-1's Avatar
yup that too!
Old Apr 24, 2010 | 03:24 PM
kinglt-1's Avatar
Multiquote works well, try it sometime!
Old Apr 24, 2010 | 11:59 PM
sayed_000's Avatar
just called the tuner back .. the numbers were right but the graph missed up while printing .
so gotta go back and print a new graph .
thanks guys for all your comments ..
Old Apr 25, 2010 | 06:29 AM
Nothing personal, but I would not 'just take somebody's word for it'. What numbers are right?
See the numbers and graph do not match. Anytime I see that, I consider it a bad pull. As a few other posters have mentioned, it looks like your AFR is not ideal. So, even if the 'numbers are right', something is still wrong.
Personally, I would do another pull. Get your AFR dialed in at ~13.0, double-check the weather data, and do another run.
Its your car..you can do what you think is best, but a cam that size should be giving you higher numbers than what you have posted.
Good luck..
