PRC 227 Automatic Dyno Results
Old May 28, 2010 | 05:00 PM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
Default PRC 227 Automatic Dyno Results
Guys we recently dyno tested a customers car that showed up with recently installed 227 heads. The car is a automatic with 4000 stall I believe.
TA
LS1
PRC 227 62cc Heads
MS4 Camshaft
Pacesetters
Y Pipe
Loudmouth
12 Bolt Rear
4L60E
Underdrive Pulley
Car was dyno tested with me rolling into the throttle so it doesn't down shift. I typically lock the tranny in 3rd, but I didnt have the hp tuners software connected so I just rolled into it. As a result I wasnt at WOT all the way till Well past 4000rpm
Enjoy!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old May 28, 2010 | 11:05 PM
TXZ28LS1's Avatar
very nice numbers TSP!! Also jason between your PRC 215 & 227 what is the difference between the 2 as far as performance goes?
Old May 29, 2010 | 03:01 PM
MYSTIC-1SC's Avatar
nice results once again.
Old May 29, 2010 | 05:02 PM
chrs1313's Avatar
very nice that combo is making good power...just to clarify the converter was locked or unlocked...
Old May 30, 2010 | 08:00 PM
Pwebbz28's Avatar
Don't be scared!! Take it to 7000!!
Old Jun 2, 2010 | 08:48 AM
TTT
These numbers were locked, it made 439rwhp if memory serves me correctly unlocked!
__________________
Jason
2005 Twin Turbo C6
Old Jun 2, 2010 | 03:59 PM
Sales2@Texas-speed's Avatar
Apples to apples, without changing camshaft or anything else, you'd likely see about 5-10hp or so by swapping to 227's from the 215's. The only real downside to the 227's is you lose about .013" of piston to valve as compared to the 215's due to the extra valve size. We do not recommend the MS4 with the 227's due to that, unless you flycut your pistons, but this guy insisted on it and just ran it without checking. I am sure it was very tight!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Jun 2, 2010 | 10:56 PM
Mazzenger's Avatar
Did you use stock rocker arms?
Old Jun 3, 2010 | 11:44 AM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
Yes, stock rocker arms on this setup!
Old Jun 3, 2010 | 03:55 PM
john563's Avatar
how much rwhp would these heads give over my stage 2.5 5.3
Old Jun 3, 2010 | 05:00 PM
LS6's Avatar
LS6
again impresive
Old Jun 27, 2010 | 05:11 AM
Public Enemy's Avatar
is this stock ls1 lifters? what is the pushrod length?
Old Jun 28, 2010 | 04:54 PM
fatmat80's Avatar
impressive results...as always TSP..
Old Jul 12, 2010 | 09:30 PM
hitamuthafcka's Avatar
Default 227 heads
Just out of curiousity matt, john or jason...was that trans am orange by any chance?
Old Jul 13, 2010 | 11:27 AM
Yes I believe this was your car Mario.
Old Jul 13, 2010 | 12:35 PM
427LS7HCI's Avatar
Very impressive
Old Jul 13, 2010 | 01:04 PM
slow trap's Avatar
mmmmm.orange
Old Jul 13, 2010 | 09:36 PM
Default 227 heads
Cool...Just wanted to make sure Ive been having friends call an mention this thread...LMAO...but i also wanted to throw out there about the specs:
stck underdrive pulley
3600 stall
stck bottomend
7.5 rods
as far as installing the fast 102 i had to sand down alil on top of the mezier water pump for anyones concern
an my pulls are as followed if im correct
1st-420
2nd-432
3rd last- 453
the #'s were impressive an the car is running great
I havent ran the car due to penwell closing down for good so im hoping to run in hobbs nm sometime soon to see my results an i also want to mention that there might be a race if the guy doesnt chicken out but i will be posting a video on youtube if it does happen...so i hope everyone will comment and view the video...as far the the other vehicle racing me it will be an 05 Lambo murcielago ....stck i believe...I will keep everyone posted on what happens....
Oh yeah an i want to thank terry for installing my heads, intake and everyone at texas speed jason for getting down on that dyno an tune, hopefully with the kill on the lambo it will bring even more customers to texas speed!
Old Jul 13, 2010 | 10:02 PM
Default 227 heads
Originally Posted by slow trap
mmmmm.orange
already!
Old Jul 14, 2010 | 07:12 AM
antonio84's Avatar
Very nice
