TEA comes out kickin...!!!!
Helped a buddy install a set of TEA 1.5s/custom cam this weekend.Hes not on the net much so I dont think he was going to make a post. Car is 02 WS6 M6. full bolt-ons. Cam was 233/237 around .600 lift on a 111. 10 bolt with 4:10s, 17" TTIIs, with 315s. No tricks, no shortbelts!!
Final #s were 463/424!!!!!!!!!!! This was with him tuning the car himself using LS1Edit. #s are STD.
I didnt expect ANYWHERE near this kind of power from his setup. Im going to try n put the graph on a disc so I can post it up for you guys. Hes making 409rwtq@4000rpms and carries it quite well to 6000rpms. Car was still pulling strong to 6800. I think hes gonna try an elec wp and a cutout and shoot for 470rwhp.
I guess I should have learned a lil before calling BS on all these big #s being made, as this is the 2nd high horsepower car in Ga with heads/cam. Both running TEAs and both making 450rwhp+!!
Needless to say, this guy is one happy camper..
how much are 1.5's? i dont see them on tea's website?
and oh ya...badass numbers!
Josh
and also.. is this another one of the "hand finished" sets... or is this a shelf stock head? Good results none the less !!
Bruce
Bruce
Found this about STD dyno correction on a yahoo search...
"Because the reference conditions include higher pressure and cooler air than the SAE standard, STD corrected power numbers will always be about 4 % higher than the SAE power numbers. "
Gomer, these are not the hand finished heads. Off the shelf 1.5s. I dont recall the exhaust flow #s, but the intake was at 309@.600. I THINK the exhaust was 250ish@.600, but TEA does flow with a pipe. TEA says they are picking up an additional 10cfm with the hand finishing. Might have been worth it to give them a try...
The heads are not decked. stock 5.3s. Pistons were flycut to make room for the stick. Compression should be right @ stock with the 5.3s/flycutting. He tuned it to 30* @ WOT on 93 pump gas.
FWIW, I didnt really post this to brag about TEA. I should have titled the thread a lil differently. I was just stoked these heads would be able to handle such a big cam and still make awesome power. We have seen these types of #s over and over again from setups all over the country. The key seems to be these huge cams and heads that can support them.....
