Raptor Cam Results
Old Aug 29, 2010 | 01:15 AM
eduardo's Avatar
Red face Raptor Cam Results
well got my car tuned today at newtech in Hayward. It's an SD tune. It dynoed 402 rwhp and 377 rwtq.
Mods are: pacesetter LT, ls6 intake, custom y, no cats, with cut out open.
This was done on a dyno jet. So what the FUDGE, I thought this MOTHER FUDGER was gonna dyno at least between 415-425.
Oh yea this is also on 853 heads.
Old Aug 29, 2010 | 01:29 AM
venom ws7's Avatar
M6 or A4? rearend? Can you post the graph?
Old Aug 29, 2010 | 01:41 AM
eduardo's Avatar
It's a m6 with stock rear end. I'm on the I-phone but I can't post graph tomorrow. Based off other raptor cam results mine seems to be on the lowside.
Old Aug 29, 2010 | 01:45 AM
venom ws7's Avatar
I agree.
What was A/F ratio like?
Old Aug 29, 2010 | 07:12 AM
TORCHD 02 TA's Avatar
You also have the worst flowing heads too.. If you had some 241s, I am sure you would be maybe 5-15 more rwhp
Old Aug 29, 2010 | 09:26 AM
Damian's Avatar
LSX Mechanic
That is a myth...
OP, post a graph.
Old Aug 29, 2010 | 09:57 AM
Titanws6's Avatar
Those seem pretty decent for cam only, what are the specs on this cam, curious.....
Old Aug 29, 2010 | 10:10 AM
RJB01camaross's Avatar
If you dont have a P&P TB and underdrive pulley. Theres about 10-15hp left on the table there. Once the graph can be seen it wil be easier to tell if you are getting all you can as it is.
Old Aug 29, 2010 | 10:27 AM
KevinR's Avatar
The specs are in my sig.
Old Aug 29, 2010 | 10:48 AM
s346k's Avatar
haha i don't buy this at all.
take it to the track and see what it traps. dyno numbers don't mean jack. i like having a 310whp car that traps 111.
Old Aug 29, 2010 | 11:25 AM
Will this raptor cam is pretty big... A nice set of better breahting 241 heads would be better than the 853s.. JMO
Case and point... My buddy has an 00 Trans Am (853 heads) and has an LS6 Intake and a Lunati 242/242 cam... On a mustang dyno made 390 RWHP
Now my car.. 241 heads, same LS6 Intake and a 228/232 cam and SAME mustang dyno (same tuner as well) I made 419 RWHP!!!
Old Aug 29, 2010 | 11:35 AM
eduardo's Avatar
I'll put the graph up in a minute.
So this is what I was told, right from the get go he new exactly what I was gonna dyno, he said with my mods I'd barely be over 400 and he was right when he meant barely (2hp over). Anyways he said with a underdrive pulley, better lid and throttle body I'd be gaining at least a good 15 rwhp.
Since the tune the car does kick ***, pulls like a mother up top and boy do I mean it pulls. I driveability still needs to be worked out but above 2rpm it drives good.
Old Aug 29, 2010 | 12:18 PM
01SS99red's Avatar
I agree dyno number meen nothing at all. my car M6 with 4.56 and 28" tire puts down 401/377 but traps 120-122 depening on the air. take it to the track and see what it does.
Old Aug 29, 2010 | 12:28 PM
ssinister550's Avatar
yea thats definately wrong the 853 heads are identical port and airflow wise to the 241's I've flow tested, measured and ported both they flow within a couple cfm of eachother stock for stock
Old Aug 29, 2010 | 02:09 PM
eduardo's Avatar
Default Here is my dyno sheet
http://i79.photobucket.com/albums/j1...2/scan0001.jpg
Old Aug 29, 2010 | 02:18 PM
Engine_HP's Avatar
nice results for a 853 heads, whats the cam specs ?
Old Aug 29, 2010 | 03:28 PM
eduardo's Avatar
I believe the specs are 236/242 111 LSA. Thanks Engine HP for the compliment. Well for anyone in near future looking to use the raptor cam, these are the results 402 rwhp and 377 rwtq. Next I'm gonna finish up installing my nitrous kit and will see how she does at the track.
Old Aug 29, 2010 | 05:01 PM
KevinR's Avatar
.236/.242 .615/.615 111
Old Sep 8, 2010 | 08:25 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I was just comparing this to my Vengence Racing VRX4 Cam which is 228/230 .58x/.58x @ 112 and mine were
385 HP
363 TQ
2002 Stock Head, LS6 Intake, P&P TB
SLP UD Pulley
SLP Lid
Dynatech SuperMaxx w/ Cats matted to a Corsa
T-56 w/ Textralia OZ700 Z grip, Steel Flywheel
3" STEEL DS (Denny's NItrous Ready)
Moser 12 bolt- 33 Spline Axles, Tru Trac Diff (heavy POS), Stock 17" WS.6 Rims
My smaller cam makes better TQ till 3.5-4k RPMS and then your peak TQ moves up a little. Willing to wager if I had a stock driveline I would be @ or past your numbers.
Even though the heads are not optimal, that cam may need more Compression like all top end cams and may see a decent bump. As well as a FAST intake (un ported) will help the combo as well.
EDIT:
Just to mention that my cam is not considered a strong runner either given the similar cars, drivetrains, mods, dynos, and conditions. I have seen mine do 405-425. Some I can account for drive train difference but I am a firm beleiver that not all cams are equally cut the same. Sometimes the cam companies mess up and you get that one or two guys who have freak dynos.
I have personally seen a custom ground 230/236 on a .550/.550 lift (i think 112 LSA) make 380 rwhp on a 98 Camaro and then put into a 2002 Camaro (same drive line/mods/tuning shop) and make 420 to the tire.) Eastside Perf (Former Holder of the LSX Nitrous Record) Did all the work on both cars and thought the 2002 had LS6 heads or some other work. Just goes to show what happens. Beleive me I wanted that Kid's cam BAD. Last I heard the 4.20 car put in larger ratio rockers, yellow terra lights, and TFS 215cc heads and made not so much more, maybe 450 which for a H/C car with those heads a kinda weak combo.
I wish I could make that **** up.
Oh and one last thing. The ONLY cam that I IMO that has almost always made consistant power is the TRex, not a cam that I would use persay but that makes decent power and for a "off the shelf" non custom grind, I think is a pretty sure bet. Though I think the company grinding it has more influence on what power you make no matter what you create for a engine combo. It almost makes you want to have every cam, "Cam Doctored"
Last edited by BlackScreaminMachine; Sep 8, 2010 at 09:05 AM. Reason: Added Points.
Old Sep 13, 2010 | 09:18 PM
1Hawk's Avatar
LS1TECH Sponsor
That is a little low... I have the RapTr in my car...makes great power...In my opinion id use the MAF and the oxygen sensors...No reason for Speed density on a street car. let the sensor make up for any tuning. there arent very many GREAT LS1 tuners around
