SPEED Inc tuned, H/C/I, A4, 346, 495rwhp 426rwtq!!!
#141
#142
#143
AC and heat are the last things to go on my car.. I'll have lightweight glass before I get rid of my AC
#144
#145
You can PM me if ya want.. I feel like this is getting pretty off topic..
Sorry Chris
#146
A/C should not be affected, it runs off a separate belt off the crank pulley
Do what you want, I spent alot of time trying to get a light heater setup, and now I finally have one, I have not seen one other person with a setup like mine.
#148
The race pump has two separate outlets that can run heater lines, or(as I do) i run the coolant from the small coolant lines that run under my manifold, to a heater core, then back to the radiator. works well and saves a tone of weight. plus the coolant that leaves the top of the heads is warmer, faster, heat comes on a bit sooner is cool weather
#149
#150
https://ls1tech.com/forums/drag-raci...till-keep.html
The link is the way me and chris run heat in are cars :-)
#151
#153
chris. Its been a a year maybe 2 I'll ask Mike again. But he told me he tuned a car with a SLP lid, and did a/b/a/b test with the bigger FTP lid and it didnt make any more power when they 1st came out.
#154
so if it is worth nothing on the dyno then basically 1 kpa of vacuum doesn't affect hp at all on my setup...
I am more curious than anything how vacuum level relates to hp output...I want to know what the point of diminishing returns is...more curious than anything...
The ram air setup kind of sparked my thoughts since it shows around 2.7mph on my car vs a stock setup...so when I measure 2.5kpa difference at 100mph was worth 2.7mph but also part of the equation is the cold air difference too...I got to set some tests up this spring and find the absolute best ram air lid setup for a 102 fast...I am going to test 2 or more setups I have rolling around in my head...
#155
#158
#159
I do only problem is you will still have that ugly part of the air box in the engine bay boo.... but if you want to keep the ac just leave the heater box and everything alone not worth the trouble at you point
#160
