SPEED Inc tuned, H/C/I, A4, 346, 495rwhp 426rwtq!!!
As some of you have been following i got my car dynoed today at SPEED INC. Changes to my car were:
1 7/8 ARH from 1 3/4 QTP
mandrel bent Y with 3"-4" flowmaster merge from bent over the knee Y with less than ideal merge
EWP
Here is the other build information in this thread
https://ls1tech.com/forums/dynamomet...dit-video.html
i went from this
to this
We could have used elbows with a bigger centerline radius to help with flow some more but i want to be able to remove the trans/crossmember without removing the exhaust...
The money Shot!!! Damn only 5 HP off...So close...maybe with 40psi in the tires, air filter removed, and pulling the belt...
Peak gains were right around 10rwhp and 15rwtq (best numbers before were 485rwhp and 411rwtq)...graph posted is an over lay of my best looking graph before with rpm shown...the 485rwhp one had an rpm pickup problem...
I was even more impressed with what i picked up down low...In some places i was up 30rwhp at 4.6K, and up 40rwtq at 3.3K-5K...
The tq curve got so much flatter it is amazing, even looks to have shifted my peak down in the RPM band...
Thank again to LARRY & everyone at SPEED INC, the Y pipe looks great, and JIM did a killer job on my tune as always...Enjoy guys...
EWP
i went from this
to this
Those are great gains IMOP! The average from 6k-6.5k looks to be up from 17-18 hp,then tapers off to around 14-15.Thats GOOD. The amount of TQ at 4K is GREAT!!!!60 fts are going to go down for sure.
I think were gonna have to play with your front shocks to limit travel so that it does not take out anything on the front end.
EWP
i went from this
to this
EWP
i went from this
to this
little bit more work and ur 500rwhp.
that's what she said...yeah me too, goes to show a well designed/flowing exhaust is just as important as a 1k fast intake on the inlet side...
makes me wonder how I would have ran SI, or CAM ONLY since this same exhaust has been on since the start...
I plan on going...just have to watch the weather
thanks bud see you in a week
hard to tell since even before with the power I was making and even the drag radials it is hard to hook on the street from anything below 40mph...
if the weather hold out we will see what it gains at the track on Sunday
