TEA C5 Nitrous graphs, bad convertor ??
Old Feb 8, 2004 | 11:11 AM
Brian Tooley Racing's Avatar
Post TEA C5 Nitrous graphs 696 RWHP, bad convertor ??
I was looking at my nitrous graphs of my new set up, and when I rescaled the X axis to speed I noticed that I must be blowing through the torque convertor.
The old setup we had was our 5.3 Stg 1.5 heads straight off the assembly line, it made 600 RWHP and went 9.87 @ 138.9.
The new setup is the Judson LS6 Stg 2.5 heads, Weiand intake, Harland Sharp rockers, and ATI underdrive balancer. When we pulled it on the dyno the run only lasted 1 sec, which is much shorter time then usual, and where the convertor used to flash to 4500, it now flashed to 5500. We did this the day we left for the Thunder Shootout.
Dyno is represented in RPM, Dyno2 is represented in speed, so you can see the "dyno" graph looks normal, but when you look at "dyno2" you notice how much less speed the car pulls to. I included a N/A pull for comparision. I guess its time to send my SY 3500 back to Yank.
Attached Thumbnails TEA C5 Nitrous graphs, bad convertor ??-dyno.jpg   TEA C5 Nitrous graphs, bad convertor ??-dyno2.jpg
Old Feb 8, 2004 | 04:48 PM
C4VetteLS1's Avatar
I found the same thing accidently on my old setup...
When i made a pull on motor it would runs 130 mph @ 6000 rpm...
Then on a 250 shot, it would only goto 115 mph @ 6000...
When id goto the track, id run out of gear at the 1000 ft mark, and my setup should have been good for 140.... I didnt understand why till i did the same graph you just did...
Brian: You can calculate converter effeciency by calclating speed at say 6000 rpm. Through your tire size (calculator for tire growth) and gearing etc....
I ended up finding out i had 18% slippage on motor and like 27% on nitrous!! geez i was pissed, swapped to a new TCI SSF 3500 converter and it dropped to 9% on motor and 11% on nitrous...and the car increased rwhp HUGE!
Old Feb 8, 2004 | 06:23 PM
Since the car wouldn't make it 60' without breaking something I never got to find out what MPH it would go. I do have a spreadsheet with a slippage calculator.
So the million dollar question is, HOW MUCH WOULD THAT LITTLE 346 HAVE MADE WITHOUT BLOWING THROUGH THE CONVERTOR?? We thought 696 RWHP was good!
Old Feb 8, 2004 | 10:44 PM
C4VetteLS1's Avatar
lol...well as bad as it looks from the mph change i would easily assume a minimum 50 rwhp was lost....
When my converter was slipping as bad as yours...I got down to the point where it was making 310 rwhp, down approx 80 rwhp from where it was when i first dynoed it several months before hand on motor....
So I was making 390 rwhp, the converter started going away the harder i sprayed the car (up to a 300) then it finally ended up at 310....on spray it would only make 450 rwhp on a 250 shot! cause it blew through so hard...
get a converter in that bitch and redyno! good luck brian
Old Feb 11, 2004 | 04:06 PM
Damian's Avatar
LSX Mechanic
Put a 6-speed in it, find out, and drive it like a real man
Old Feb 11, 2004 | 09:51 PM
All you big guys with two legs just think your the $hit. Theres not too many guys that can drive a car with 700+ RWHP down the track with a stick. Maybe if my name was Allen Futral or Ron I could. Of course a stick will generally break long before an good auto.
I once owned a Jeffco, which is a copy of a Lenco, 5 levers, one for every gear, and you don't have to clutch it to change gears, now thats a transmission!! But as self employment goes, needed money sold it with clutch and bellhousing for $5000. The guy that bought it ended up on the cover of Summit catalog. Now that would be way cool in my C5. Wonder what my wife would think if she got in it to drive it
Old Feb 12, 2004 | 12:51 PM
C4VetteLS1's Avatar
Heheh...if only they had a reliable 6-spd setup that could handle 800-900 rwhp and 1.3 60 fts...
Old Feb 12, 2004 | 01:34 PM
UnbelievabLS1's Avatar
Talking
Originally Posted by Brian Tooley
I once owned a Jeffco, which is a copy of a Lenco, 5 levers, one for every gear, and you don't have to clutch it to change gears.....
Ahhhh....lemme guess.....you couldn't reach the clutch pedal with the seat all the way up? :p It's tough enough just stretching that one leg far enough to reach the gas huh?
Old Feb 12, 2004 | 02:11 PM
C4VetteLS1's Avatar
ahhh picking on poor brian... Is he short or something? (from the sound of it)
Old Feb 12, 2004 | 02:46 PM
Nah....Brian's not short, he's just vertically challeneged! Maybe when I come back to the shop next week, I'll build him an adapter for his gas pedal so he can sit all the way back in his seat!!
Brian, you know I'm just teasing ya bud, you know there's no way I would be able to do what I'm doing without ya....you rock brotha!!!!
Old Feb 12, 2004 | 02:48 PM
C4VetteLS1's Avatar
Make it some custom billet pedals that are a couple inches thick
Old Feb 12, 2004 | 03:20 PM
Damian's Avatar
LSX Mechanic
There is, but nobody wants to pay for it....Custom built Richmond T-56 w/ gear ration's to your liking, Billet shaft, cryo'd parts, Twin Disk clutch.....
There is a dozen or more LT1 cars in Atlanta making 500-700 rwhp running STOCK t-56's without problems....
