stock ls1 with ls6 cam
You also need LS6 valve springs. 7.425" long pushrods are a good idea too. Some people get away with the stock pushrods though.
copied from TR's website:
LS6 Camshaft - 204/218 .551/.541 117.5 LSA Please note that this cam has approximately a 0.050" smaller base circle than a stock LS1 camshaft. This smaller base circle will require longer pushrods for applications with stock length valves and no milling for the head surface.
For the 01 ls6 through I don't think that's true since the 01 Z06 used the solid valves.
with you current 7.4 pushrods you're not achieving the full .551/541 lift which is why your factory springs haven't broken yet. Replace the springs with either ls6/ls2 springs which are good to .560-.570 lift respectively & cheaper. Get the correct length(longer) pushrods . This will give you full lift of your cam at the valve & will likely correct the missing power.
As stated, the small gains you would see wouldn't be worth the beating your motor would take at those rpms for most people.
I didn't say it wouldn't make power, I said there was no need.
