TEA-TFS215/EPS/Fast102/NW92 **Updated**
#41
The rear suspension has the QA1 adj shocks, the spohn anti-roll drag bar, adj torque arm, and lcas. The only front suspension is I removed the sway bar. Honestly I hope the transmission breaks, its been such a piece of junk. When it does break I am starting fresh I dont even want to use the housing. Not sure what else I can really do as far as bolt on changes. Any sugestions?
An underdrive pulley would be your last big power gain for bolt ons
#42
I have an underdrive pulley already just not listed. Yeah I'm not sure on what tire for the back. I have been lookin at slicks. I have the Weld Rts front runners. I have been looking at front shocks also just unsure what to get. I like the QA1s so maybe just a front set.
#43
I run strange single adjustables and a 275 spring in the front. They can be cranked up for excellent street response, then adjusted when at the track. Obviously they worked great for my car, but I wish I went with a double adjustable.
I run the same 315 et street as you in street trim and Hoosier QTPs on my drag setup. The QTPs feel the same as the MT radials in terms of traction on the street, but holy **** do they hook at the track.
I compared my dyno graph to yours and its within 5 hp at every point. I think its weird you are only trapping 116 with such similar power. Whats your raceweight and DA usually like?
