408ci, GT47-88, Stock 317 heads
236 236 .587 .587 112.5
8.5:1 CR
T56
Going back in a few weeks for a final tune on race gas.![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
302 Found
302 Found
15lbs. 93oct 16* timing, 10.3 AFR
![](http://i34.photobucket.com/albums/d133/jaypee1217/93octdyno.jpg)
higher undisclosed boost level
, 114oct. only 13*timing, 10.3 AFR. seems to be alot left on the table ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/383993_704782553395_44405533_34625502_971476432_n.jpg)
8.5:1 CR
T56
302 Found
302 Found
![](http://i34.photobucket.com/albums/d133/jaypee1217/fd0d97cf.jpg)
the dyno sheet shows no signs of the car getting choked up. So the heads seem to be working well. Should be an easy 40+HP at the same boost level with just timing and fueling tweaks.
http://youtu.be/1FOnzonT6qI
in the second video of the first set you posted. there is a corvette in the background any info and pictures lol.
But on a lighter note I was on my way to build a similar setup. What water pump are you using? Who build your trans?
and how much power do you think truck manifold would have robbed you?
no info on the vette. was just a car at the shop I was dynoing at. I don't think truck manifolds would have robbed alot. they're proven in 1000hp setups.
stock T56 until it pops. might put a sprayer on it for the highway racing I do.
water pump is a meizere radiator mounted. burkhart sells them.
Hey if you ever get the time, or feel safe enough doing it lol, could you possible get a clearer shot at the speedo while you are doing a pull? I am working on a build now and would love to see how it pulls on the street.
