Heads and cam result
2002 Camaro Z28 A4
PP LS6 59cc heads
Comp cams XER 226/.584/114 cam
HS 1.7's
ZO6 mass air
Accufab TB
Rollmaster double chain
ASP underdrive pulley
Kateck belt tensioner
NGK55 plugs
Taylor wires
3.73 gears in stock 10 bolt
Slp Torque arm
All that was installed.
There was no before dyno runs
Before mods were
SLP LT"S w/cats
Borla cat back w/ middle plate
Slp lid/K&N
Smooth bellows
Trans go shift kit
275/40/17 nittos
Mikey dyno tuned car after install
Air/fuel ratio right around 12.8:1
timing around 28 degrees
Horsepoer #'s locked are 403
Torque unlocked was 378
What do you guys think
Car has 5,000 miles on it
Peace
Ever
Peace
Ever
I have the dyno chart, and i tried to attach it but it says file too big? Its 242 and it says max is 100
btw.. mail me the graph to sculbert1@netzero.net and I'll host it when I get to work in the morning.
foff667
That is why I said with the right gear, suspension and traction he'll hit it
I would guess 11.3@120mph unlocked with stock rear gears on ET street and 3500 stall at 3500-3600 pounds
This is thru the exhaust,with an auto.It also has 373 gears.This car will be fast.
