MS3 with LS6 heads and intake results...
The car made 432hp and 395 Tq. This is on a M6 2000 ls1 (118k miles) with Pacesetter Lts, TSP ORY, Corsa, TSP lid w/ K&N, ported TB, LS6 intake, TSP MS3, and a set of stock LS6 heads. The car has a Moser 12 bolt with 4.10s, a huge Strange chromoly drive shaft, and stock (118k mile) clutch.
I took it to Bryan at Reckart Performance Tuning in Austin TX, and this guy knows his stuff. He got the A/F perfect, drivabilty is great, and he did it all in about 2 hours. He said my injectors are maxed out and could used a bigger maf. I also think we could have squeezed a couple more out if it if the clutch wasn't giving out, and the weather was a bit cooler. All in all I am really happy with these numbers considering it was through a 12 bolt with 4.10s.
I plan to go back soon once I get a set of injectors, bigger maf, a new clutch, and 150 shot of nitrous.
I will try to post a idle vid when I get a chance, it sounds amazing through Cosra.
Here is a pic of the Dyno sheet.
ive got a 01 trans am ws6 with a vortech v-9 with 9 lbs on it ... whats the best heads and cam upgrade for cheap....
There is also a head with the same port as the LS6 but lowers the compression but I cant remember the casting number, with those you could up the boost.
You could find a set of those puppies cheap on several forums....
Although you're making about 25 more hp with the 243s
