Dyno Compare TPIS Widemouth Vs. Fast 90mm!!
Here's a link to the testing we did with the fast intake & the TPIS intake. All testing was done on our 99 Corvette ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Here's the link for the complete graph
http://www.corvette-tech.com/showthread.php?t=67
Here's the dyno sheet!
![](http://www.texas-speed.com/images/90mmTSP.gif)
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
If I remember correctly, isn't the TPIS TB you used an oval shape TB? I wouldn't expect an oval shaped TB to perform very well on an intake with a circular opening, being that the TB is what, a 78mmx90mm TB going onto FAST's 90mmx90mm opening?
What I'd like to see is a FAST intake with FAST TB against the TPIS Intake w/ TPIS TB.
Hopefully FAST will get off their ***** and get us some TBs!!!
LS1TECH & Trucks Sponsor
Originally Posted by HOSS99
So, Which one is the tpis?
-Matt-
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic3451_2.gif)
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
What I'd like to see is a FAST intake with FAST TB against the TPIS Intake w/ TPIS TB.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Ditto!!
This was a fresh build-up for the Heads/Cam class at the SBSO so we did not do baseline runs with an LS6 intake. We will be dyno testing the FAST intake with their 90mm TB as soon as we receive one, and of course those results will be posted!
-Matt-
-Matt-
__________________
LSxGuy widda 9sec Mustang
Blue Graph = TPIS Oval TB, TPIS Oval LS6 Intake
Red Graph = TPIS Round 90MM TB, FAST 90MM Intake
Here's the right link to the graph: http://www.texas-speed.com/images/90mmTSP.jpg
Originally Posted by -Joseph-
We didn't use the Oval TB on the 90mm FAST intake. I believe it was Cartek that had that setup at the corvette tuner shootout though (w/ adapter) and it seemed to do pretty well. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
LS1TECH Sponsor
Was an 85mm used on both applications? If so, thats the bottleneck. You really need to run the 90mm setups MAFless in SD tune to reall see the benafit of such a large mouth I'd think.
If both setups are still breathing through the same smaller diameter MAF why would you see that great of a difference?
MAFless would be the way to go with the 90mm. Of coarse now, having 90mm intake, 90mm TB, 85mm MAF, you still will probably have a restriction along the line somewhere. You can go as far to say that the current air lid technology isn't enough. IMO the 90mm stuff (and matching components) is probably best left to high revving 346ci engines, or anything with big cubes behind it.
verbs - I think that setup, intake and TB was in the 1500 range if I remember right!
