Engine Dyno : NA 5.3, LS3 Heads, 9.5:1 = 500hp
Figured I would share this, got my 5.3 done this week and dyno'd it today. I built it for boost, so it's only 9.5:1 compression. It has a 239/243 .623/.623 116 cam, installed 112ICL. Stock LS3 intake, LS3 heads. 4.020 bore x 3.276 (4.8L) stroke.
Looking to double this output and then some, with the turbo setup very soon. I just have to buy some fuel system parts so I can feed the beast. It is on E85 also. The turbo system will consist of a C6/truck manifold hot side, PT8847 .96 turbo, with a 4" down pipe. Those results coming soon!
It made right at 500hp @ 7000RPM / 430 ft lbs. @ 5400RPM today naturally aspirated.
[youtube]DxUTC37i_bQ[/youtube]
[youtube]TLp_UzPX_c8[/youtube]
Build thread is here in the FI section if you want to take a look.
https://ls1tech.com/forums/forced-in...stock-rad.html
Clean build, I like those numbers. Any reason you went with a 5.3 over the lq9 everyone is useing? Seems like most lq9's with that same setup are only netting about 450hp.
They won't work on a standard bore 5.7 or smaller. 4.00 minimum. I don't think the aftermarket small bore ls3 heads will work either. None the less, I've been wanting to see a set of ls3 heads on a short stroke engine. Looks like the work well. I would like to see the torque and power curve down low as well. Any dyno sheets?
Look at the engines Chevrolet is building for the whippeled (2.9L & 4.9L) 327ci COPO camaros. They're using a 4.065" bore on a 3.150" stroke!
Not to mention the fully CNC'd LS7 heads with 275cc intake port volume, 89cc exhaust port volume, 70cc combustion chamber volume. This is all in an LSX iron block. Hot Rod did a full article on it in the August '12 issue. In testing GM spun these things to 8 grand no problem...and it's available as a crate motor.
COPO 327/4.0L - supercharged engine GM Part# 17802827.
Great results Jakson! Can't wait to see what the turbo adds.
Yep it comes out to a 5.4, its a 332 cubic inch. It's just more fun to call it a 5.3 with LS3 heads because it throws people off a little.
I have dyno sheets but forgot them at work, I will get them tomorrow.
Short block consists of a 2004 LQ9 6.0 block, bored .020 over. A stock 2006 4.8L crankshaft with an LME billet 24x reluctor. Callies Compstar H beam SBC 6.300" rods, and Diamond 4.020" pistons which I moly coated the skirts, and ceramic coated the tops. A comp 239/243 116+4 cam, and Morel link bar lifters. It should rev really nice, can't wait to get it in the car. Was perfectly happy going to 7500 on the dyno, even with the stock intake, was still making 485 at 7500. With some forced air behind it, turning it 7500+ shouldn't be out of the question at all, as long as the springs will make it that high.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
