VR C7 Stingray- 511RWHP/442RWTQ Cam Only-Detailed build pics/video/dyno graphs inside
We've had the pleasure of having our very own C7 Stingray in house for a couple of days now (an upgrade over our outgoing C6 Grand Sport) and WOW... What a car! Excellent build quality, fantastic engine, quality suspension and drivetrain upgrades, and amazing looks. The interior is simply amazing. The style and feel of the C7 is truly impressive. Obviously we purchased our C7 to perform research & development on the Gen V LT1 engine & E92 ECU. Stay tuned as this thread will constantly be updated with our findings/modifications/packages etc.....
Day 1: Burnouts.
Yes, with only 8 miles on the odometer we felt the need to leave our mark at the dealership.. Speaking of dealerships, we purchased our 2LT/Z51/Bi Mode equipped Stingray from Rick Hendrick in Duluth Georgia. Dan & Chris are the Corvette Team at Hendrick and both guys have been absolutely amazing to deal with, not only on this purchase but on our 2013 Grand Sport as well. If you are in the market for a new Stingray or a C6 I would definitely consider them when shopping around!!
![](http://www.fototime.com/4839A8EC8BF2B57/orig.jpg)
Unfortunately our Stingray came with chrome wheels... We had to get these coated ASAP to hold us over until our 360 Forged SL10 Concave set up arrives
If anyone is interested in the 20/19 Z51 combo they will be available in 2 to 3 weeks.
The wheels, front grill, and ride height were all tackled at once. We had to drop it and black it out for it to work right in our parking lot!![](http://images.corvetteforum.com/images/smilies/yesnod.gif)
![](http://www.fototime.com/34409CE9901A9EF/orig.jpg)
![](http://www.fototime.com/087A17AEB24EB22/orig.jpg)
Of course, we also had to get it on our in-house chassis dyno to make some baseline pulls and get inside the factory E92 ECU for some tuning. Stock, the C7 (manual 7-speed) put down a respectable 423-rwhp and 417 lb-ft of torque. With tuning we picked up 25-rwhp and 34 lb-ft of torque, which you can REALLY feel on the street. Final numbers were 448-rwhp and 451 lb-ft of torque, which is impressive for an otherwise STOCK "base model" Corvette.
![](http://www.fototime.com/F3D9E4C119DD7CA/orig.jpg)
![](http://www.fototime.com/9048925B37C0F76/orig.jpg)
Tomorrow our C7 hits the lift for its next round of modifications....
Vengeance Racing custom Camshaft ( Keeping VVT/Deleting DOD)
Vengeance Racing Dual valvespring kit
Vengeance Racing Hardened Pushrods
Katech C5R Timing Chain
Comp Cams Trunion Upgrade
Comp 850-16 Lifters
Pfadt Race Engineering Tri Y Stainless Longtube Headers with 3" ORX
Nitrous Outlet C7 LT1 Plate Kit with Dedicated Fuel System
Custom Tuning VIA Vengeance PCM
We hope to have updated #s on our cam/header package by the end of the week!! We will update this post during the build and post an idle clip as soon as it is available!!
Aside from camshaft development we are currently working on CNCd LT1 cylinder heads as well as a custom turbo system over the winter.
For those of you who are new to the Corvette community and havent heard of Vengeance Racing I would encourage you to check out our website at www.VengeanceRacing.net .. You can check out several of our featured builds on our forum as well at http://forum.vengeanceracing.net/forum.php
Feel free to PM/email/Post any questions you might have.
Day 1 Teardown begins
![](http://www.fototime.com/55F2E40BDC5AE40/standard.jpg)
Half hour later all engine covers/PCV/shrouding has been removed
![](http://www.fototime.com/8037CEB72A311D7/standard.jpg)
Factory Exhaust Vs Pfadt Tri Y Headers & X pipe
![](http://www.fototime.com/B02C202C734D897/standard.jpg)
Newly designed valve covers. Notice the baffling/oil drain back provisions. GM Really stepped up their game here
![](http://www.fototime.com/6C6DE96BEAD0CC5/standard.jpg)
LT1 Intake Manifold- Once we removed the multitude of engine covers and insulation we found the actual intake manifold itself...
NOTE: For anyone removing their intake at home, the insulation cannot be removed without the intake without damaging the insulation.
![](http://www.fototime.com/E6468781838EE15/standard.jpg)
LT1 Waterpump
![](http://www.fototime.com/22B4E4905DE14AF/standard.jpg)
LT1 Thermostat/Housing
GM went to a plastic housing and the thermostat is that of a Gen III LS1 (part of the housing itself)
![](http://www.fototime.com/1DBA597867B67F7/standard.jpg)
Engine Bay shot with valve covers/intake removed
Here you can see the fuel rails/DI fuel pump
![](http://www.fototime.com/87459DBF2FDFAB5/standard.jpg)
Another angle... Hey something familiar.. Check out the rocker arms
![](http://www.fototime.com/6B3E4AD74E98999/standard.jpg)
Close of shot of a DI injector
![](http://www.fototime.com/42932AC583C6F3E/standard.jpg)
Getting closer- One cylinder head down, one to go
![](http://www.fototime.com/DB25C810570F236/standard.jpg)
Close up shot of shortblock. Notice the shape of the pistons
![](http://www.fototime.com/721CDB71AC74EF3/standard.jpg)
DOD Lifters
![](http://www.fototime.com/439D7F76463A3BB/standard.jpg)
Day 2 Progress
Combustion Chamber Pics.. Notice the DI Injector provision
![](http://www.fototime.com/B72E870A6073A6B/standard.jpg)
Front Sway bar & Streering rack are removed for access to front cover
![](http://www.fototime.com/CE6806F796EB1E1/standard.jpg)
Front Cover Removed revealing VVT Cam Gear and newly designed oil pump
![](http://www.fototime.com/C2B980B2230F1FD/standard.jpg)
Unfortunately the days of simply lowering the oil pan to remove the oil pump are long gone. The new LT1 oil pump sits much deeper in the pan and GMs use of RTV sealant instead of gaskets makes removing the oil pan completely the only option. Fortunately this is doable with the engine in the car with a bit of creative thinking
![](http://www.fototime.com/04BC44F3BE084FF/standard.jpg)
A look inside the Z51 Dry Sump Oil Pan
![](http://www.fototime.com/311070F317C0BCE/standard.jpg)
GM LT1 Dry Sump Oil Pump- The 2nd picture shows not only the pick up, but the bolt and portion of the oil pump that sits nearly an inch inside of the pan.
![](http://www.fototime.com/03BE69CE685E714/standard.jpg)
![](http://www.fototime.com/17E18EE2401075C/standard.jpg)
GM LT1 Fuel Pump
![](http://www.fototime.com/0E0CC0B17A03E8A/standard.jpg)
This is the "Lifter" the fuel pump rides on
![](http://www.fototime.com/0EF4329800B15AA/standard.jpg)
Out with the old... In with the new
![](http://www.fototime.com/B889559671A3874/standard.jpg)
Checker springs to verify PTV
![](http://www.fototime.com/3AE15A575F6E77B/standard.jpg)
Verifying PTV-
![](http://www.fototime.com/DD166F88C98848D/standard.jpg)
Day 1: Burnouts.
![](http://forums.corvetteforum.com/images/smilies/rock.gif)
![](http://images.corvetteforum.com/images/smilies/smile5.gif)
Comp 850-16 Lifters
LT1 Waterpump
DOD Lifters
Day 2 Progress
GM LT1 Fuel Pump
Verifying PTV-
New VR Camshaft/Katech C5R Timing Chain & Comp VVT Phaser Limiter installed and engine going back together.. This wraps up day two progress
![](http://www.fototime.com/D9CE73BF449A734/standard.jpg)
Final Day Assembly Pics
Checking Install height on LT1 cylinder heads with our VR Dual Spring Kit
![](http://www.fototime.com/81252B251D9DCB8/standard.jpg)
One head down... One to go...
![](http://www.fototime.com/18DE69D7FEBC717/standard.jpg)
As mentioned above we went with Pfadt Tri Y Stainless Longtubes. The driver side went in with no issue and fit so well it had to be held in place to avoid falling out of the car. The passenger side did take a little work, but nothing we arent used to. As you can see, we spaced the cradle down a bit and the header slid right in.
![](http://www.fototime.com/9250D05B394A181/standard.jpg)
Here is a shot of the complete exhaust system
![](http://www.fototime.com/AF22DF5FC5ADCEA/standard.jpg)
With both cylinder heads in place it was time to install pushrods/rockers... Here is a nice shot of why we upgrade the factory rocker arms with the Comp Trunion Kit. I dont know anyone who feels its a good idea to have all of these needle bearings making their way thru your engine...
![](http://www.fototime.com/6B1CF35BB613A63/standard.jpg)
OE Rocker arm with trunion upgrade installed
![](http://www.fototime.com/97A60319800044C/standard.jpg)
Final button up of engine
![](http://www.fototime.com/63D0E1635493E6D/standard.jpg)
We aren't 100% finished with tuning just yet, but we have a few other cars that need our attention so this is it for today...
![](http://www.fototime.com/193B517AD2C73E4/standard.jpg)
We will get back on the dyno in the next day or two and dial in the VVT on the bottom end. I believe there is some additional power under the curve to be had with additional tuning.
We also have LMRs new CAI on the way for testing as we saw MAP readings drop to 90kpa above 4500rpm... The next step will be CNC LT1 Cylinder Heads.
Last but not least here is the idle clip...
That's a nice car you have there, I can't wait to see one in person. Thanks for posting so many pictures up that way everbody can check all the new stuff on the lt1 out. Those are great numbers too, so I guess the vvt lets the timing change so the engine is always making around the same horpower and torque at the same time? Is that why they chose to use this, bc overall performance will be better instead of a certain point in the power band/ rpm?
Nice writeup, but ya lost the bottomend torque. Too bad.
We fully expect to pick up some power under the curve this week on the dyno. As I said earlier in the post, we had not spent alot of time on VVT tuning.
We will post updated #s as soon as we come off the dyno.
FWIW, we had an opportunity to participate in a few roll races in Mexico this weekend against an 09 C6Z with CAI/Full tune making 500rwhp.. Two races from 3rd gear roll and we pulled both times.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
14 Second Truck Club
This is awesome. Subd. Mods for these cars are coming in faster for this motor than what everyone thought they would, thanks for letting us see yours lol.Btw what is that clear plastic stuff on the fenders of the car? Im guessing its to protect the customers car.
Wish you had dyno'd after the LTs and mids with stock internals!
It is ridiculous that this little 6.2L is making over 500whp with a stock intake setup. Amazing what good heads and DI can do for a motor! I loved the curves on your HP-tuned version.
Sidenote - you just stripped down a brand new motor on a brand new car. Dedication!
Sidenote - you just stripped down a brand new motor on a brand new car. Dedication!![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
