c5 pt88 402
Old Dec 9, 2013 | 01:53 PM
ghost-1's Avatar
Default c5 pt88 402
Car was on 18psi pump gas with 50/50 meth was scrubbing the tires so dont know it it effeted the numbers or not.
Old Dec 9, 2013 | 03:52 PM
Stang2Goat's Avatar
******* awesome, sir!
More motor info would help - pistons, rings, gap, heads and cam info, SCR, etc.
The runs were very consistent and you can see how the torque came up as timing as added to the tune. :-)
Also what car and trans is this setup in? -mcs
Old Dec 9, 2013 | 03:53 PM
Stang2Goat's Avatar
Edit - viewing from mobile device so I can't see your sig just posts. Apologies if my answers are in your sig already.
Old Dec 9, 2013 | 04:15 PM
sick_tight's Avatar
what heads and CR are you running?
Old Dec 9, 2013 | 04:32 PM
ghost-1's Avatar
Its a lq4 block 317 heads tooley plantinum springs 317 heads 234 236 .612 lift 115 lsa ls9 gaskets, hellfire rings gaped at 27fast 102 nw102 tb, je pistons callies bottom end mcleod rxt tr6060 3.5 aluminum ds solid couplers front and rear
317 heads 10.5 compression ratio
Old Dec 9, 2013 | 05:34 PM
sick_tight's Avatar
thats an awesome setup. ive just got a N/A 402 and i think its pretty quick. i bet that car disappears faster than miley cyrus's dignity.
any pictures?
Old Dec 9, 2013 | 05:51 PM
ghost-1's Avatar
any pictures?
Ha ha ha winning there, I will snap a couple and post em up. I can't really get on it right now its been pretty cold and raining so she stays in the garage. Hopefully we can hit montgomery again this weekend and seew hat she can do.
Old Dec 10, 2013 | 07:08 PM
Rob Carlson's Avatar
hows the strokers been holding up? i'm doing a 403 myself
but its going into a mustang... haha
Old Dec 10, 2013 | 07:09 PM
well.. i mean an 04 cobra
Old Dec 10, 2013 | 10:35 PM
ghost-1's Avatar
Motor is running good have had a few problems with the old turbo kit but that is all square now. I am pretty happy with the curve I was worried the motor would be to big for the turbo.
Old Dec 11, 2013 | 03:19 PM
632b00's Avatar
Should be a blast!
Old Dec 12, 2013 | 08:55 AM
ghost-1's Avatar
Originally Posted by 632b00
Should be a blast!
Yeah hoping to hit the track sunday.
Old Jan 10, 2014 | 12:52 PM
got-a-ls1's Avatar
awesome numbers! i have a very similar setup that made 880 at ~20 psi through a locked 4l80e. afr 225 heads, victor jr intake and a decent sized cam. my horsepower curve looks almost identical to yours peaking around 5300 and holding steady from there haha
