Tick ls7 polluter cam/Heads/I, Dyno results
After having the car for over a year now...I decided to do some work to it. This thing is loud as hell at idle and I will try to upload a video.
Mods:
VR/WCCH stage 2 heads unmilled
VR Ported FAST 102 intake
FAST billet rails
Stock throttle body
Halltech Super Bee MF105S
Tick Performance Ls7 Polluter cam
Katech C5R Timing Chain
Comp pushrods
160-degree thermostat
LG 1 7/8 headers
Off-road X-pipe
Corsa cat-back exhaust
Results:
586.82 RWHP/529.97 lb-ft of torque
Mods:
FAST billet rails
Stock throttle body
Comp pushrods
LG 1 7/8 headers
Off-road X-pipe
Results:
Great job! Love the torque!
One of the great things about the ls7 is it has 4cc valve reliefs from the factory. It also has a 12 degree valve angle which gives much more distance for the valve to drop to the deck surface.
This gives a lot of room to run a big cam and higher compression. With 12:1 compression this combo would be well over 600/540.
I bet it's a rocket and it will love nitrous!
This is our ls7 polluter cam btw and it's not nearly as big as you would think.
Reviewing a data log and the KPA towards the end of the run would show if there was a restriction in the system.
I would imagine a large cubic inch engine like this with a good sized cam and ported heads would benefit from a 102mm TB.
The only draw back is cost. A lot of money to spend on a TB just to pick you up maybe 10rwhp.
Money would be better spent on a nitrous kit and spraying a 100 shot to pick it up a substantial amount of horsepower.
