408 Build dyno numbers are in
On a big cube motor going from an LS6 and STOCK size LS1 tb to a ported 102/102 will give big number returns with those heads and that cam.
Someone suggested finding a 90/90 cheap- why go through swapping intakes if not to get the biggest return? Weird.
And those that said "not a big believer in dyno numbers blah blah" then don't post in the DYNAMOMETER section lol
MAMOFIED Ported FAST 102 + NW 102 TB worth AT LEAST 30/30! on your combo maybe 35+ @ Peak vs current combo and huge area under the curve starting at 2500 RPM with 20+ lb ft.
On 4" Stroke + Ported/Aftermarket Heads + Med/Big Cam at least
10-12 HP maybe 15.
Don't think unported FAST 90/90 worth 25-30, 15-20 more likely.
