441c.i. LSX Nitrous Build N/A dyno as well as other dynos...
2006 Pontiac GTO
575rwhp corrected on Mickey Thompson ET Street II
441 c.i. (7.2 Liter) LSX block
PBJ Performance Nitrous Build
Top End
100mm MAF, 100mm Intake, Nick Williams 102 T/B,
102mm Fast Intake manifold with Nitrous Outlet Fogger.
Heads
PRC LS7 285cc CNC ported Heads
ARP 2000 Head studs
Lower End
Callies 4.125 Crankshaft, Callies Rods,
Wiseco Pistons
ATI 10% underdrive Super Damper
Exhaust
Kooks Signature Series Stepped Headers 1 7/8" x 3"
Kooks 3" Off Road Mid Pipes, X-pipe, Cut outs
Magnaflow 3" Competition Catback
Top End
Heads
ARP 2000 Head studs
Lower End
Wiseco Pistons
Exhaust
No, only the street at KC and Indiana Street Car Takeovers.
Dig races and rolls in Indiana on this vid. GTO is fully weight with competition audio system.
Indiana SCT Soco Street - YouTube
Dyno numbers is not a big deal. You can loose 20rwhp with a drag radial easy if not more. 80+ degree weather don't help either. I'm more than happy with the result of the races the car has ran from digs and rolls.
Cam is a nitrous cam, custom. Compression undisclosed.
However, there is a difference between drag radial and street tires. Even air pressure makes a difference.
The taller tire and 15inch wheel may take gear out of the car which could be favorable to the dyno numbers, but the might be negated by the drag radial losses.
Most importantly, I picked up at least 100 hp and 95 ft-lb switching from a 6.0 LS2 heads, cam, fast intake/tb to the 7.2 liter LSX on the same Dyno with room to spray 400+ shot of nitrous.
It should be a fun time.
