First Dyno today. Does this look right?
This look REALLY low even where the shift point is located. The car doesn't run any better now than it did with the factory cam. It sounds a lot better, but pretty disappointing.
Some dynos are all over the place. Easily would have made another 25-30hp at a higher RPM though.
You could post the tune in the tuning section of this site and maybe gain some insight there as to how it looks. A crappy tune could be holding you back if that's the case.
Put some good tires on the car and re-dyno it to 6500 RPMs.
KW
I think I have another issue. Apparently the air filter set-up is not big enough for the engine. I have to change that out and change tires, then head back.
Thanks for all the replies!
