Highest dyno with stock manifolds and cats?
I'm on my 5th LS1 project. I love the sound and the stealthy nature of running factory cast iron manifolds and cats, especially for a nice daily driver. I'd like to make 400+ rwhp naturally aspirated running the factory exhaust and dual/dual catback. Stock displacement too. I know it's doable, but I'm not sure how small of a cam I can get away with by doing it. Ported LS6 heads or 205cc AFR heads with LSX intake would be a must. A 224/224 cam would most likely do the trick along with the killer heads, but this cam also has lots of valve clatter due to its fast ramps. I don't want noisy valvetrain. ZO6 cams are quiet, but I'm not sure if they can get me to 400 rwhp without headers. Again, this is my car, so don't criticize me for running an oddball combination. Nobody said making 400+rwhp with factory exhaust and stock displacement was going to be easy. To me, that's part of the appeal.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
I'm not against headers in general. They make power. I've run headers in 3 of my 5 LS1 project cars. Problem is, headers make the car sound tinny, trashy, and non stock. I want this car to look and and sound stock (at a glace), but haul ***. Again, I have different goals for this car. I want great idle quality, good gas mileage, and low noise. My old 2000 WS6 ran 11.0s with factory exhaust and a 150 shot. Best car I ever had.
__________________
Picked up a pair of extrude honed cast iron manifolds for my 3rd Gen before deciding to go with custom headers for it. The extrude honed manifolds were ~1/8 to 1/16 bigger in the primaries and collector than the stock manifolds I had to compare against.
I think going for 400+ with manifolds will have exhaust restriction. I think a traditional split with extra exhaust duration will help in your goal. The LPE GT2-3 cam is similar to the Z06 and has more punch but might still be on the small side 208/220 118.5 LSA. Maybe a scaled up version of something like that might be worth thinking about, TR old man cam or even a 224/228 etc
I'd go 218-224 560-565 114LSA
TEA or SAM (Your Boys) S1.5 (small runner hand ported and good flow to 570 lift)
LS6 int.
PTB
EWP
Good catback
Ported or E.honed stock manifolds
Rest of the basic boltons w/edit tuning
10-bolt 3.73's
I bet your close to 400RW threw a stick..
A4----------->forgetta bout it
LS6 int.
PTB
EWP
Good catback
10-bolt 3.73's
This is interesting because that was originally going to be my goal with my rebuild. Altough I was going to try and hit 400rwhp with an 02 LS6 Cam, Stage 1 heads, stock 01 cats/manifolds, and tuning. It was a stretch I know and I've since gone another route but I did do a lot of research on it. Patrick, an example would be Jason99TA. If I remember correctly, Jason hit 393 rwhp with a rebuilt motor (like mine), 02 LS6 cam, stock heads and Mac's with no cats. My rationale was that I would have heads instead of headers and I would hopefully be around same place he would be. I think an LPE GT-2 Cam or an MTI Stealth II cam would net the better power with a nice set of heads though. As far as the heads you can never go wrong with SAM, I would go for at least an 11:1 CR as bumping the CR will always help your hp. Another combo that seemed to work was mating an 02 LS6 cam with SLP 1.85 rockers, this increases the lift to just under .600; so if you had a nice set of stage 2 heads that peaked at a .600 lift it would allow them to breath to their potential. Speed Inc. did this on their Z06 (Stage 2 LS6 heads, stock LS6 cam, 1.85 rockers, longtubes) and made 420rwhp, so minus 20 rwhp or so for no headers you'd technically be right around there. I know a lot of this is bench dynoing so to speak and everyone's car is different but hope this helps.
Any more info on this? I seem to recall Zed over on LS1.com dynoing an MMS head and cam package with stock manifolds and coming up with some 400ish horsepower numbers. But this was a few years back and I'm sure that post got lost in a server crash or something.
LS1Tech Premium Sponsor
My wife's 3500 stall sleeper cam only car puts about 340rwhp to the ground. I think with some good heads 375 rwhp could be possible in a a4 converter car through stock manifolds & cats
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Hey Patrick I can totally see your viewpoint. My Z06 now makes 460RWHP and is as loud as a racecar-it was cool at first but I want stealth and total driveability. This is my daily driver so it's a little to obnoxious for daily driving. actually i'm in the midst of installing a smaller more streetable cam and installing the factory Ti exhaust-I figure I lose about 10 horse but gain a much more enjoyable daily driver. Anyway-400rwhp through cats and a tiny cam is very possible. A guy on the CF forum did a AFR head (on a Z06) swap only and made 410 at the wheels through the factory cats, manifolds, TB, Intake-he only had a aftermarket airbox. My car for example made 377 with just an airbox and ran 11.60@118 on et streets. Can the Z06 manifolds be adapted to work on f-bods? The Z06 maniflod almost looks like a shorty header and flow really good and so do the Z06 cats-plus the manifolds are cast iron and hold heat to really get the exhaust flowing. I personally think u can get more than 400 with a good set of heads, a more aggressive but quiet cam, fast intake and ported TB-I can see 425+. What about that old man grind u had. Keep us posted i would love to see your progress!
I'd also suggest getting some Random Tech Cats & y-pipe. You will get a little deeper tone from the bigger y, but not the rasp of headers. And you'll let whatever cam, intake & heads you choose flow better, plus you'll pick ~20rwhp (or at lest I did with a pure stock motor....313 to 334)
I had a setup similar to what you are talking about for awhile on my car. Stage 1 heads and a 228/232 cam through stock manifolds/cats and a stock WS6 catback. The car sounded nice and quiet and made 396rwhp
This was also with a stock lid and maf on the car.
I am interested in going this route as well. I would like more power but not neccesarily with headers, I am looking at adding a cam(not sure which yet), ls6 intake and high flow catted y-pipe, and maybe heads.
Does anyone know if the 99 manifolds are better or worse than the newer ones??
LSX Mechanic
I've seen 415/390 through stock man and cats. TEA heads & TSP cam...
Patrick, I disagree with your statement. It is not the headers that make these cars sound like that. It is the lack of cats. Putting high flow cats on makes a WORLD of difference, and you still have the advantage with all of the sound.
Personally I think modding a bone stock motor internally is quite silly without proper intake and outake air flow. Cats will solve your problems. Run headers..
'98-99 manifolds/cats are 5-10 rwhp worse than the '00 and newer versions.
__________________
