Huron Speed H/C/I boosted ls1 results
Results all in all aren't too bad I think, but just want to hear what others think. As we know, track is what matter but just out of curiosity does this sound right to others?
After small random issues, final numbers were 551rwhp / 540rwtq @ 10psi with a conservative safe tune. Also guesstimating around 580rwhp at 11psi, and 640rwhp at 14psi. I plan to run the car at a solid 11psi on average since It's normal pump 93, and no meth involved. My previous numbers for h/c/i only were a best of 412rwhp, while on another dyno with nothing changed, 380rwhp. So overall it's seems like about 200rwhp increase.
Full Mod List:
-Cross Slotted Cryo Rotors w/Carbotech XP8 Pads
-17x9/17x11 Fikse FM5's in technipolish finish
-Texas-Speed 228R camshaft w/112 LSA
-PRC Dual Spring
-Texas Speed 7.300 Chromoly Push Rods
-Texas Speed Ported LS6 Oil Pump
-LS2 Timing Chain
-Katech CNC Ported/Polished 806 Heads
-4.10 rearend gears
-LS6 Intake
-Ported/Polished Profession Products 85mm Throttle Body
-Comp Oil Less 7875 Single Turbo
-4inch Intercooler
-Bosch 80# Flowmatched Injectors
-Walbro 450lph Pump
-Custom 3inch Straight Exhaust
-BMR Turbo Tubular K-member
-Founders Performance Adjustable Torque Arm
-Founders Performance Subframe Connectors
-Founders Performance Adjustable Panhard Bar
-Founders Performance LCA's
-Founders Performance Relocation Brackets
-Tick Performance Adjustable Clutch Master Cylinder
-Monster Clutch LT1-SC Twin Disc Clutch
-Turbosmart Hyper-Gate 45 & Raceport 50mm
-Built to max **** 10bolt rear, welded tubes, Girdle, Weld in brace on tubes, axles, fresh bearings
-LS9 Map Sensor
-LS9 Head Gaskets
-ARP Head Studs
-Fresh gaskets on everything
-Fresh Amsoil in everything (oil, power steering, tranny,rear, brake, coolant, etc)
Other Misc mods and fabrications not to mention random things I forgot.
Full Mod List:
-PRC Dual Spring
-LS2 Timing Chain
-4.10 rearend gears
-LS6 Intake
-4inch Intercooler
-Walbro 450lph Pump
-LS9 Map Sensor
-LS9 Head Gaskets
-ARP Head Studs
Whats your comp ratio & timing? Wandering how much the ls9 gaskets lowered your compression & if timing is real conservative. Im also not sure I buy into swapping cams. I made 704rwhp on 13lbs & my cam is definitely not considered a "BOOST" cam (236/246 612/612 110 lsa).. That was with 18 degress timing on E85.
This was from 5 years ago https://ls1tech.com/forums/forced-in...0-12-5lbs.html
I recently got the car going again this year and put it on my buddies brand new load bearing dynojet and the recent results are on the last page. We have 91 pump gas here and I have 11:1 compression so I spray 100% methanol injection. My buddy has a stock bottom end 78mm turbo LS1 with lower compression 317 heads and hes made 748 rwhp on straight 91 octane.
Yes the exhaust kills the car but it's the quietest car around. When I open the 4" cutout I gained 4 mph in the 1/4.
Anyways FCSS I would say something is off on your car and if I had to guess it would be that comp turbo. I've never seen good results from comp turbos and from my past research they use shitty straight trim turbine wheels that don't work well on v8s.
Post up your dyno graph, I bet you can see where it runs into backpressure.
